The QSW-2104-2T is an easy-to-use unmanaged switch with 2-port 10GbE RJ45 and 4-port 2.5GbE RJ45, allowing you to upgrade your network environment by connecting a wider range of devices with different bandwidth requirements. Featuring a near-silent fanless design and compliance with IEEE 802.3az (Energy Efficient Ethernet, EEE), the QSW-2104-2T operates quietly and with optimal power usage. With high performance and superb functionality, the QSW-2104-2T is the ideal choice for creating an affordable high-speed network environment in your home or workplace.
Maximum flexibility with multiple 10G and 2.5G Ethernet ports
The QSW-2104-2T features 10GbE and 2.5GbE RJ45 ports for connecting various bandwidth-demanding devices, and supports the NBASE-T standard for connection using Cat 5e or Cat 6a cabling. With the QSW-2104-2T, you can easily create a hybrid high-speed network in homes and offices to accelerate file transfer, virtual machine applications, multimedia streaming/sharing, and more. -
Future-proof your network environment
QNAP offers comprehensive, budget-friendly storage and networking solutions that provide an array of connectivity possibilities. Easily and flexibly upgrade your workplace or home network now to handle bandwidth-hungry applications. -
Auto-negotiation for optimal speed of connection
No complex settings are required to use the QSW-2104-2T - simply connect your devices and it's ready to use. The QSW-2104-2T supports auto-negotiation that optimizes transfer speeds and performance for each connected device. -
Loop detection and blocking
The QSW-2104-2T features network loop detection. If a network loop is detected, the QSW-2104-2T automatically locks the looped ports to ensure the network environment quickly resumes normal operation. -
Near-silent and energy saving
The QSW-2104-2T features a fanless design for near-silent operation. The unique ventilated construction assists in cooling without disrupting your quiet environment while maintaining high performance. IEEE 802.3az (EEE) support also reduces power consumption without sacrificing performance or functionality.
- QNAP QSW-2104-2T - switch - 6 ports - unmanaged
- Switch - 6 ports - unmanaged
- Subtype
- 10 Gigabit Ethernet
- Ports
- 2 x 100/1000/2.5G/5G/10GBase-T + 4 x 100/1000/2.5G
- Performance
- Non-blocking switching throughput: 30 Gbps , Switching capacity: 60 Gbps
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Flow control, full duplex mode, fanless, EEE
- IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
- 18 cm x 14.5 cm x 3.4 cm
- 722 g
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- Ports
- Performance
- 16K entries
- 9KB
- Status Indicators
- Port transmission speed, power, link/activity, loop
- 4 x 10/100/1000/2.5G RJ-45 , 2 x 10GBase-T RJ-45
- Power Device
- External power adapter
- 12 Watt
- Included Accessories
- 4 foot pads, mounting screws, 2 anchors
- VCCI, BSMI, CCC, FCC, KCC, LVD, Class B
- 18 cm
- 14.5 cm
- 3.4 cm
- 722 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
