QNAP QSW-1208-8C 12 port Unmanaged Gigabit Ethernet Switch
Quicklinx: DK3SWS00 Mfr#: QSW-1208-8C
Type: 10 Gigabit Ethernet
Ports: 12
Managed: No
POE: No
£677.73 ex VAT
£813.27 inc VAT
The QNAP QSW-1208-8C is a 12-port 10GbE unmanaged switch, allowing you to instantly upgrade your network environment at a cost-effective price. The QSW-1208-8C supports 10GBASE-T and NBASE-T standards, allowing you to take advantage of higher network speeds with your existing Cat 5e and 6a cables. Both SFP+ (fiber) and RJ45 (copper) ports are available (with 8 combo ports) for servicing a range of network needs. Compliant with IEEE 802.3az (Energy Efficient Ethernet, EEE), the QSW-1208-8C is energy efficient as well. With high performance, low latency and superb functionality, the QSW-1208-8C is the ideal choice for upgrading your home or business network to support 10GbE connections.
  • Faster speeds using existing cables with 10GBASE-T & NBASE-T
    The QSW-1208-8C is compatible with 10GbE and NBASE-T technologies to provide higher transmission speeds with existing cables. Depending on cable types and their lengths, different speeds can be achieved for faster, more efficient data transfers. The QSW-1208-8C is also backwards compatible to provide connectivity with legacy devices.
  • Flexible deployment with eight combo ports
    The QSW-1208-8C offers a combination of 12 SFP+ (fiber) ports and 8 combo RJ45 (copper) ports for connecting different interfaces to the same switch. With RJ45 interfaces, 10 GbE is supported with Cat 6a (or above) cables. Alternatively, direct attach copper (DAC) cables can be used with SFP+ ports for connecting to servers inside a rack. The switching capacity of the QSW-1208-8C is 240 Gbps, guaranteeing the full potential of each port.
  • Near-silent and energy saving
    With its smart cooling system, the QSW-1208-8C works quietly to ensure high-speed network performance without generating distracting background noise. IEEE 802.3az (EEE) support also reduces power consumption without sacrificing performance or functionality. By dynamically detecting link speeds and activities and adjusting accordingly, the QSW-1208-8C provides energy savings of up to 50% to minimize lifetime operational costs.
QNAP QSW-1208-8C - switch - 12 ports - unmanaged - rack-mountable
Switch - 12 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
4 x 10 Gigabit SFP+ + 8 x combo 10 Gigabit SFP+
Performance
Switching capacity: 240 Gbps
Priority queues: 8
MAC Address Table Size
27K entries
Jumbo Frame Support
9KB
Flow control, full duplex mode, Energy Efficient Ethernet, CoS
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az, IEEE 802.3bz
AC 120/230 V (50 - 60 Hz)
28.5 cm x 23.3 cm x 4.3 cm
2.15 kg
Enclosure Type
Desktop, rack-mountable
Subtype
10 Gigabit Ethernet
Ports
Performance
Priority queues: 8
27K entries
Jumbo Frame Support
9KB
Status Indicators
Port transmission speed, power, link/activity
12 x 10GBase-X SFP+ , 8 x 10GBase-T RJ-45
Internal power supply
Rubber feet, power cord
Rack Mounting Kit
Included
28.5 cm
23.3 cm
4.3 cm
2.15 kg
10 - 85% (non-condensing)
Ports: 12
Managed: No
POE: No
Brand: QNAP
Price Range Ex VAT: £500 - £750
