QNAP LAN-10G2T-U 10GBase-T HBA  Rack
Quicklinx: BRVNWS00 Mfr#: LAN-10G2T-U
QNAP LAN-10G2T-U - Network adapter low profile - 10Gb Ethernet x 2 - for QNAP TS-1279U-RP, TS-1679U-RP, TS-879U-RP, TS-EC1279U-RP, TS-EC879U-RP
  • Enhanced connectivity
    With dual 10GBase-T ports, this network adapter offers enhanced connectivity options for your PC, ensuring high-speed data transfer rates of up to 10 Gbps. Its compatibility with Ethernet 10GBase-T cabling means seamless integration into existing network infrastructures.
  • Compact and efficient design
    Designed with a low-profile form factor, this plug-in card fits easily into your PC, making it an ideal choice for systems with limited space. Its efficient design does not compromise on performance, providing reliable, high-speed connectivity.
QNAP LAN-10G2T-U - network adapter - 10Gb Ethernet x 2
Network adapter
Plug-in card - low profile
Ports
10Gb Ethernet x 2
Cabling Type
Ethernet 10GBase-T
10 GigE
Data Transfer Rate
10 Gbps
QNAP TS-1279U-RP Enterprise, TS-1279U-RP Turbo NAS, TS-1679U-RP Turbo NAS, TS-879U-RP Turbo NAS, TS-EC1279U-RP Turbo NAS, TS-EC879U-RP Turbo NAS
Network adapter
Ports
10Gb Ethernet x 2
Wired
Cabling Type
Ethernet 10GBase-T
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
2 x 10GBase-T
Compatible Slots
1 x Expansion Slot - low-profile
