QNAP LAN-10G2T-U - Network adapter low profile - 10Gb Ethernet x 2 - for QNAP TS-1279U-RP, TS-1679U-RP, TS-879U-RP, TS-EC1279U-RP, TS-EC879U-RP
Enhanced connectivity
With dual 10GBase-T ports, this network adapter offers enhanced connectivity options for your PC, ensuring high-speed data transfer rates of up to 10 Gbps. Its compatibility with Ethernet 10GBase-T cabling means seamless integration into existing network infrastructures. -
Compact and efficient design
Designed with a low-profile form factor, this plug-in card fits easily into your PC, making it an ideal choice for systems with limited space. Its efficient design does not compromise on performance, providing reliable, high-speed connectivity.
- QNAP LAN-10G2T-U - network adapter - 10Gb Ethernet x 2
- Network adapter
- Form Factor
- Plug-in card - low profile
- Ports
- 10Gb Ethernet x 2
- Cabling Type
- Ethernet 10GBase-T
- Data Link Protocol
- 10 GigE
- Data Transfer Rate
- 10 Gbps
- Designed For
- QNAP TS-1279U-RP Enterprise, TS-1279U-RP Turbo NAS, TS-1679U-RP Turbo NAS, TS-879U-RP Turbo NAS, TS-EC1279U-RP Turbo NAS, TS-EC879U-RP Turbo NAS
- Network adapter
- Form Factor
- Ports
- 10Gb Ethernet x 2
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- 2 x 10GBase-T
- Compatible Slots
- 1 x Expansion Slot - low-profile
- Designed For
