Enhanced compatibility
Designed specifically for PC systems, this memory module ensures seamless integration and optimal performance with its system-specific upgrade type. -
High-speed performance
With a memory speed of 2400 MHz and compliance with PC4-19200 specifications, users experience swift data processing and improved system responsiveness. -
Reliable design
Featuring a non-ECC, unbuffered design with a CAS Latency of CL17, this module delivers reliable performance while maintaining data integrity. -
Efficient operation
Operating at a low supply voltage of 1.2 V, this DDR4 SDRAM module ensures energy-efficient performance without compromising on speed or reliability. -
Easy installation
The DIMM 288-pin form factor allows for easy installation in compatible PC systems, making it an ideal choice for system upgrades or replacements.
- QNAP - A1 version - DDR4 - module - 16 GB - DIMM 288-pin / PC4-19200 - unbuffered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 2400 MT/s (PC4-19200)
- Latency Timings
- CL17
- Unbuffered
- Voltage
- 1.2 V
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL17
- Non-ECC
- Unbuffered
- Module Configuration
- 2048 x 64
- Chips Organization
- 1024 x 8
- Voltage
- 1.2 V
- RoHS
