QNAP - DDR3L - module - 2 GB - SO-DIMM 204-pin - 800 MHz / PC3L-12800 - unbuffered
Quicklinx: G60HWS00 Mfr#: RAM-2GDR3L-SO-1600
Type: DDR3L SDRAM
Capacity: 2GB
Connection: SO-DIMM 204-pin
Speed: 800MHz
Registered/Buffered: Unbuffered
£49.59 ex VAT
£59.50 inc VAT
Marketing description is not available.
  • Enhanced compatibility
    Designed specifically for PC systems, this memory module ensures optimized performance, making it a suitable upgrade for system-specific needs.
  • Efficient performance
    With a memory speed of 1600 MHz and compliance with PC3L-12800 specifications, this DDR3L SDRAM module boosts your system's efficiency and responsiveness.
  • Low power consumption
    The low voltage feature of this memory module, requiring only 1.35 V, leads to reduced power consumption and a cooler running system, contributing to its longevity.
Memory module
2 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
800 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
2 GB
Upgrade Type
System specific
DRAM memory module
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
Type: DDR3L SDRAM
Capacity: 2GB
Speed: 800MHz
Brand: QNAP
