Product
Brand
Q Acoustics Media 4 (M4) Soundbar with Built-in Subwoofer
Quicklinx: D4J2WS00 Mfr#: QA7410
Audio System Type: Soundbar
£290.84 ex VAT
£349.00 inc VAT
Soundbar with built in subwoofer
  • Multi-Award winning, What HiFi? Product of the Year from 2014 to 2016
  • 180 degree sound with BMR loudspeaker technology – delivers room-filling sound
  • Built in subwoofer
  • aptX lossless Bluetooth for audio streaming V4.0
  • Plug & Play with all important cables and wall bracket Included
The Soundbar For Music Lovers
A soundbar never sounded this good. This multi award-winning soundbar has been designed by a Hi-Fi company, for a true music lover and is guaranteed to bring your home audio to life.
Whether music, movies or gaming is your thing, the M4 is truly the modern day HiFi allowing you to connect and stream seamlessly from multiple devices with Bluetooth and NFC so you can enjoy both TV audio and your favourite tracks from your preferred streaming service.
The M4 delivers genuine audio with no effects. A true sound system that fills your home with full-bodied, crystal clear audio.
Innovative Room Filling Acoustics
The M4 ensures that no matter where you are in your room, you will be hearing all the detail, every beat, and enjoying your music to its maximum potential.
This is thanks to clever, wide dispersion driver technology and a powerful built in subwoofer, which not only effortlessly fills your room with crisp and detailed audio, but also provides powerful, controlled bass.
Seamless Connectivity
We believe in Hi-Fi connectivity so the soundbar incorporates Bluetooth aptX TM and NFC, which means you have full connectivity and streaming flexibility from any Bluetooth or NFC device. Enjoy your music from your favourite streaming service including iTunes, Spotify, Deezer and Tidal.
We have taken care to reproduce whatever signal you put into your soundbar as accurately as possible; giving a greater dynamic range and signal to noise ratio than a typical soundbar.
Connect and play. This is the soundbar for connected music lovers.
Intelligent Home Integration
Our intelligent pre amplifier has been engineered for easy TV integration. User experience is paramount, and we believe in simplicity. Using the Optical Out from your TV (2 channel PCM) the M4 will detect when you want to watch, and when you do not. All you need do is turn your TV on.
Don't want another remote control confusing your setup? We have taken the time to ensure that our product will work with leading satellite and cable infra-red (IR) remote controls.
The M4 will intelligently integrate into your home entertainment system. Simple. Effective. Intelligent.
Q Acoustics M4 - sound bar - wireless
Sound bar - 2.1-channel
Speaker Type
Active
Nominal Output Power
100 Watt
Frequency Response
20 - 20000 Hz
Amplifier
Integrated
Bluetooth, NFC
Audio Formats
MP3, apt-X
Speaker Details
Sound bar - stereo - 2 x 25 Watt - active , Sound bar - subwoofer 50 Watt - active
Built-in Decoders
SBC decoder, aptX
100 cm x 14.2 cm x 9 cm
4.9 kg
Speaker System
Speaker Type
Active
100 Watt
Frequency Response
20 - 20000 Hz
Signal-To-Noise Ratio
85 dB
Total Harmonic Distortion
1.0%
Amplifier
Integrated
Bluetooth 4.0, Near Field Communication (NFC)
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Recommended Placing
Wall-mountable, table-top
Built-in Decoders
SBC decoder, aptX
Audio Formats
MP3, apt-X
Additional Features
aptX Bluetooth technology
Speaker System Details
Speaker Details
Driver Details
Sound bar: subwoofer driver - 3.94 x 5.91" , Sound bar: 2 x full-range driver - 2.56 x 2.56" - Balanced Mode Radiator (BMR)
Connector Type
Audio line-in (RCA x 2) , Audio line-in (mini-phone stereo 3.5 mm) , Subwoofer output (RCA) , Digital audio input (optical) (TOS Link)
Remote control, 2 AC power adapters, wall mounting bracket
Power Source
AC power adapter
100 cm
14.2 cm
9 cm
4.9 kg
Brand: Q Acoustics
Price Range Ex VAT: 150 - 300
