More stations, digital quality
DAB digital radio brings you a diverse range of great content in highly-detailed, digital-quality sound much of which is only available on digital radio. Digital radios automatically find all your available stations and let you select them by name, and there's also FM for any station that have not yet gone digital. Siesta S2 is also Digital Tick approved so you can be rest assured that your radio is ready for any future FM to digital radio switchover. -
CrystalVue display
Siesta S2 includes a clean, edgeless large format display. Read the time or radio information with ease, from anywhere in the room. Display brightness can be set manually or to automatically adjust - no more light distractions, allowing you to sleep peacefully. -
Alarms, sleep and snooze
Convenient one time set up of your daily, weekday or weekend alarms. The sleep timer allows you to gradually fall asleep without the worry of the radio playing all night. The snooze function allows you to catch those valuable extra minutes in bed. -
Simple to use
User friendly controls and large textured snooze button makes operating Siesta S2 simple and effortless, even with one eye open. -
Great sound
Siesta S2 uses a 2.5" full range speaker powered by a digital amplifier to deliver surprising audio performance from a compact clock radio. -
Auto clock and memory
Siesta S2's clock automatically sets the time from the radio signal, meaning the clock is always accurate. Siesta S2 remembers all of your alarm and radio preset settings, without the need of a battery backup. -
Headphone output
Siesta S2 also includes a headphone output for private listening, ideal while others are trying to rest.
- PURE Siesta S2 - clock radio
- Product Type
- Clock radio
- Enclosure Colour
- White
- 13 cm x 13.7 cm x 5.7 cm
- Display
- LCD
- Clock
- Alarm, snooze, sleep timer
- Radio
- DAB/DAB+/FM - 10 preset stations
- Speakers
- 1 x speaker - built-in - 2 Watt
- Product Type
- Clock radio
- Enclosure Colour
- White
Audio System
- Functions
- DAB radio, radio
- Built-in clock
- Timer
- Snooze, sleep, wake
- Alarm Wake-Up Modes
- Melody, radio
Display
- LCD
Speaker System
- Speakers
- Driver Details
- Speaker driver: 1 - 2.5"
Radio
- Radio Tuner
- Digital radio tuner - DAB/DAB+/FM
- Digital Tuner Band
- DAB-III Band
- Tuner Frequency Range
- FM: 87.5 - 108 MHz, 174 - 240 MHz
- Tuning Display
- LCD display
- Preset Station Qty
- FM Preset Station Qty
- 5 preset stations
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , USB
- EMC, LVD, ETSI EN 300 401, Directive 2014/35/EU, Directive 2014/30/EU
- 13 cm
- 13.7 cm
- 5.7 cm
