In-Car 90W Universal Laptop Charger
The 2-Power In-Car 90W Universal Laptop Charger comes supplied with 8 tips that cover over 95% of all Laptops & Notebooks on the market. It is an extremely small adapter with snap on tips that automatically sense and select the correct voltage for your laptop. This means it is incredibly safe and easy to use without the worry of damaging your laptop.
You can also charge USB chargeable devices such as Tablet PC's or Smartphones via a single usb socket.
Also includes 12V DC Car Plug. (Not Suitable for 24V Trucks).
- 2-Power Universal - car power adapter - 90 Watt
- Car power adapter - external
- 60 g
- Input Voltage
- 12 V
- Power Capacity
- 90 Watt
- Output connectors
- 1 x power , 1 x 4 pin USB Type A
- 6.7 cm x 5.3 cm x 1.8 cm
- 1-year warranty
- Input Voltage
- 12 V
- Power Output Connectors Details
- Power Capacity
- 90 Watt
- Limited warranty - 1 year
- 6.7 cm
- 5.3 cm
- 1.8 cm
- 60 g
