- 2-Power Main Battery Pack - laptop battery - Li-Ion - 5200 mAh
- Laptop battery
- 308 g
- Battery
- Lithium Ion - 5200 mAh
- Batteries Qty
- 1
- 8 cm x 20.5 cm x 2.1 cm
- Designed For
- Compaq CQ45; Presario CQ40, CQ41, CQ45, CQ50, CQ60, CQ61, CQ70, CQ71; HP G50, G60, G61, G70, G71, HDX X16-1000, HDX X16-1001, HDX X16-1005, HDX X16-1010, HDX X16-1025, HDX X16-1040, HDX X16-1044, HDX X16-1056, HDX X16-1060, HDX X16-1155, HDX X16-1160, HDX X16-1299; Pavilion dv4, dv5, DV6
- Laptop battery
- Quantity
- 1
- Technology
- Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 5200 mAh
- 8 cm
- 20.5 cm
- 2.1 cm
- 308 g
- Designed For
- Compaq CQ45-800LA, CQ45-802TU , Compaq Presario CQ45-700LA, CQ45-707TU , HP G61-429WM, G71-333CA , HP Pavilion dv4-1000ea, dv4-1000et, dv4-1001ax, dv4-1001tu, dv4-1001tx, dv4-1002ax, dv4-1002tx, dv4-1003ax, dv4-1003tu, dv4-1004ax, dv4-1004tx, dv4-1005tx, dv4-1006tx, dv4-1007tx, dv4-1008tx, dv4-1009tx, dv4-1010tx, dv4-1011tx, dv4-1012tx, dv4-1013tx, dv4-1014tx, dv4-1015tx, dv4-1016tx, dv4-1017tx, dv4-1018tx, dv4-1019tx, dv4-1020tx, dv4-1021tx, dv4-1022tx, dv4-1023tx, dv4-1024tx, dv4-1025tx, dv4-1026tx, dv4-1027tx, dv4-1028tx, dv4-1029tx, dv4-1030ee, dv4-1030ei, dv4-1030ej, dv4-1030tx, dv4-1031tx, dv4-1032tx, dv4-1033tx, dv4-1034tx, dv4-1035tx, dv4-1036tx, dv4-1037tx, dv4-1038tx, dv4-1039tx, dv4-1040ei, dv4-1040tx, dv4-1043tx, dv4-1044tx, dv4-1045tx, dv4-1046tx, dv4-1047tx, dv4-1050ee, dv4-1050er, dv4-1050tx, dv4-1051tx, dv4-1052tx, dv4-1053tx, dv4-1054tx, dv4-1055tx, dv4-1070ee, dv4-1070er, dv4-1070es, dv4-1080ei, dv4-1100ea, dv4-1111tx, dv4-1112tx, dv4-1113tx, dv4-1114tx, dv4-1115tx, dv4-1117ca, dv4-1124tx, dv4-1155se, dv4-1199ea, dv4-1520la, dv4-1622la, dv4-2154ca, dv5-1147la, dv5-1209eo, dv5-2035dx, dv5-2045dx, dv5-2046la, dv6-1007tx, dv6-1110eo, dv6-1120ep, dv6-1131sa, dv6-1149wm, dv6-1160ep, dv6-1170ep, dv6-1203ax, dv6-1240ef, dv6-1246eo, dv6-1308el, dv6-1315ec, dv6-1317ss, dv6-1320en, dv6-1320eo, dv6-1320ep, dv6-1340ef, dv6-1420sw, dv6-1425ei, dv6-1430ey, dv6-2003so, dv6-2021el, dv6-2025sf, dv6-2040sa, dv6-2060so, dv6-2105eo, dv6-2108ea, dv6-2108eo, dv6-2108sa, dv6-2110ax, dv6-2110ef, dv6-2110el, dv6-2110eo, dv6-2110ss, dv6-2114ef, dv6-2116sg, dv6-2117ax, dv6-2117sa, dv6-2120so, dv6-2122ez, dv6-2123el, dv6-2124el, dv6-2125ew, dv6-2126eo, dv6-2126ew, dv6-2127el, dv6-2130el, dv6-2130ew, dv6-2132eo, dv6-2136el, dv6-2136eo, dv6-2137sl, dv6-2140eb, dv6-2141sl, dv6-2142sl, dv6-2145sf, dv6-2147es, dv6-2150es, dv6-2151cl, dv6-2155ew, dv6-2160eg, dv6-2166sb, dv6-2168sl, dv6-2171nr, dv6-2171sl, dv6-2175ss, dv6-2180ey
