Whether you require a replacement battery, or an additional pack to keep you working, PSA has a power solution to match.
- 2-Power Main Battery Pack - laptop battery - Li-Ion - 4400 mAh
- Laptop battery
- 349 g
- Battery
- Lithium Ion - 4400 mAh
- Black
- 8.9 cm x 13.6 cm x 1.9 cm
- Designed For
- Acer Aspire 3100, 3690, 5610, 5630; TravelMate 4200
- Laptop battery
- Black
- Technology
- Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 4400 mAh
- 8.9 cm
- 13.6 cm
- 1.9 cm
- 349 g
- Designed For
- Acer Aspire 3100-1033, 3100-1052, 3100-1104, 3100-1352, 3100-1405, 3100-1458, 3100-1509, 3100-1709, 3100-1868, 3100-1972, 3100-1974, 3690-2008, 3690-2009, 3690-2070, 3690-2083, 3690-2087, 3690-2119, 3690-2138, 3690-2150, 3690-2164, 3690-2173, 3690-2196, 3690-2208, 3690-2268, 3690-2306, 3690-2363, 3690-2408, 3690-2430, 3690-2436, 3690-2468, 3690-2481, 3690-2485, 3690-2495, 3690-2510, 3690-2513, 3690-2518, 3690-2522, 3690-2524, 3690-2612, 3690-2639, 3690-2654, 3690-2662, 3690-2693, 3690-2710, 3690-2711, 3690-2780, 3690-2806, 3690-2813, 3690-2819, 3690-2848, 3690-2861, 3690-2862, 3690-2875, 3690-2906, 3690-2914, 3690-2922, 3690-2929, 3690-2949, 3690-2955, 3690-2970, 3690-2983, 5610, 5610-2018, 5610-2075, 5610-2173, 5610-2252, 5610-2312, 5610-2418, 5610-2762, 5610-2998, 5610-4039, 5610-4075, 5610-4083, 5610-4130, 5610-4145, 5610-4147, 5610-4179, 5610-4182, 5610-4238, 5610-4254, 5610-4323, 5610-4349, 5610-4377, 5610-4537, 5610-4592, 5610-4594, 5610-4608, 5610-4612, 5610-4621, 5610-4680, 5610-4687, 5610-4693, 5610-4711, 5610-4720, 5610-4762, 5610-4877, 5610-4884, 5610-4948, 5630-6009, 5630-6122, 5630-6124, 5630-6141, 5630-6152, 5630-6172, 5630-6183, 5630-6197, 5630-6254, 5630-6288, 5630-6361, 5630-6368, 5630-6431, 5630-6459, 5630-6472, 5630-6496, 5630-6551, 5630-6641, 5630-6655, 5630-6665, 5630-6670, 5630-6672, 5630-6675, 5630-6690, 5630-6715, 5630-6760, 5630-6803, 5630-6833, 5630-6845, 5630-6864, 5630-6891, 5630-6943, 5630-6951 , Acer TravelMate 4200-4053, 4200-4056, 4200-4091, 4200-4106, 4200-4135, 4200-4263, 4200-4269, 4200-4297, 4200-4301, 4200-4320, 4200-4323, 4200-4345, 4200-4347, 4200-4372, 4200-4373, 4200-4378, 4200-4380, 4200-4430, 4200-4449, 4200-4469, 4200-4493, 4200-4510, 4200-4528, 4200-4533, 4200-4539, 4200-4555, 4200-4603, 4200-4713, 4200-4732, 4200-4751, 4200-4754, 4200-4764, 4200-4795, 4200-4831, 4200-4836, 4200-4839, 4200-4854, 4200-4870, 4200-4889, 4200-4913, 4200-4926, 4200-4972, 4200-4978
