Whether you require a replacement battery, or an additional pack to keep you working, PSA has a power solution to match.
This battery is designed for Toshiba Satellite 1900 series:
Satellite 1905;
Satellite 1905-S277;
Satellite 1905-S301;
Satellite 1905-S302;
Satellite 1905-S303;
Satellite 1905-S304;
Satellite 1950;
Satellite 1955-S801;
Satellite 1955-S802;
Satellite 1955-S803;
Satellite 1955-S804;
Satellite 1955-S805;
Satellite 1955-S806;
Satellite 1955-S807;
HP Pavillion ZE1000, ZE1110, ZE1115, ZE1210, ZT1000;
Acer Aspire 1400;
Acer Aspire 1350;
Acer Aspire 1300 series;
Acer Aspire 1306;
Mitac 8640; Mitac 8575A; Mitac 8575; Mitac 8375; Mitac 8175; Mitac 8170;
Time Traveller.
Efficient Power Output
This power adapter provides 90 watts of power, ensuring that devices receive the energy they need for optimal performance. -
Versatile Voltage Range
With a voltage output of 18 to 20 V, this adapter is compatible with various devices, making it a flexible choice for users. -
Convenient External Design
The external form factor of the adapter allows for simple and quick connections to devices, enhancing user experience.
- 2-Power - power adapter - 90 Watt
- Power adapter - external
- Output Voltage
- 18 - 20 V
- Power Capacity
- 90 Watt
- 5.5 cm x 13.1 cm x 2.9 cm
- Output Voltage
- 18 - 20 V
- Power Capacity
- 90 Watt
- 5.5 cm
- 13.1 cm
- 2.9 cm
