Proper Heavy Duty Swing Arm TV Bracket White
Quicklinx: C7C6WS00 Mfr#: P-SWB223W-1
Hurry, only 1 left in stock!
£14.40 ex VAT
£17.28 inc VAT
This heavy duty, long arm design offers both a wider swing area and a flatter rest depth than a conventional swing arm bracket. This not only helps provide perfect viewing comfort, but also gives customers the flexibility if the area of installation is confined. Cable clips are provided to maintain an organized finish.
Proper Heavy-Duty Swing Arm TV Bracket mounting kit - for LCD display - white
Mounting kit
Mounting Components
Wall mount, swing arm
Adjustable Depth
5.6-51 cm
Tilt
-15° to 15°
Pan
180°
Levelling
-3° to 3°
Adjustments
Levelling, tilt, swivel, depth
2.21 kg
Recommended Use
LCD display
Recommended Display Size
23"-55"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 200 x 100 mm, 300 x 300 mm
Max Load Weight
35 kg
White
Adjustable Depth
5.6-51 cm
2.21 kg
White
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
23"-55"
Tilt
-15° to 15°
Pan
180°
Levelling
-3° to 3°
Adjustments
Max Load Weight
35 kg
Brand: Proper
