Proper Classic Swing Arm Wall TV Bracket for TVs 17"-37"
Quicklinx: 8PM6WS00 Mfr#: LDA02-221
Type: Mounting kit
More than 50 In Stock
£11.06 ex VAT
£13.27 inc VAT
Marketing description is not available.
Proper Classic Swing Arm TV Bracket mounting kit - for flat panel
Mounting kit - wall-mountable
Mounting Components
Wall mount, swing arm
22 cm 22 cm
Adjustable Depth
10-23 cm
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
17"-40"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 200 x 100 mm
Max Load Weight
30 kg
Material
Steel
22 cm
22 cm
Adjustable Depth
10-23 cm
Material
Steel
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
17"-40"
Adjustments
Tilt
Max Load Weight
30 kg
Swivel adjustment
Type: Mounting kit
Brand: Proper
