Promise Promise Pegasus R4
Quicklinx: 7RPBWS00 Mfr#: H5185ZM/A
Promise Pegasus R4 is the first four-bay high-performance hardware RAID solutions designed to unleash the raw power of Thunderbolt. Pegasus R4 features four 1 TB 7200-rpm hard drives in a compact hardware RAID enclosure with Thunderbolt connectivity. Delivering over 500 Mbps of disk performance, Pegasus is compatible with Mac systems with Thunderbolt and required Thunderbolt cable.
Thunderbolt technology is a high-speed, dual-protocol I/O technology designed for performance, simplicity, and flexibility. Capable of delivering a blistering two channels of bi-directional 10 Gbps per port of performance, Thunderbolt technology combines PCI Express and Display port into an interface using a single cable for connectivity to devices. Thunderbolt technology was developed by Intel and brought to market with technical collaboration from Apple.
Pegasus R4 is ideal for creative pro workstations, small servers, power users, and consumers who desire stylish high-capacity external storage with high performance and enterprise level data protection. Pegasus R4 is capable of delivering over 500 Mbps of bandwidth that is 10 times faster than USB 2.0.
  • Easy to use management software
    Pegasus R4 comes preconfigured out of the box. Simply unpack, connect the power cable, connect the Thunderbolt cable to the Thunderbolt port on your computer and you're ready to store music, photos, videos, and documents or ingest and edit production video.
  • Storage for the digital home
    With two channels of bi-directional 10 Gbps performance Thunderbolt allows you to back up your computer while editing the video of your summer vacation and listening to an iTunes playlist. Fast, safe, and reliable external storage is essential to protect your music, photos, videos, and other valuable data. Pegasus R4 provides massive storage space and fast performance for popular applications such as iTunes, iPhoto, iMovie, Garageband, Photoshop, and media center applications.
  • Blistering performance and unparalleled flexibility
    With over 500 Mbps of performance Pegasus R4 with Thunderbolt delivers a massive and unprecedented leap in raw power and performance for amateur professionals, audio engineers, photographers, and video post production engineers. Final Cut professionals can ingest, edit, and playback multiple streams of uncompressed HD 10-bit and 12-bit video while protecting valuable workflows, audio sessions, and other creative media content with Promise's enterprise level RAID 6 engine featuring mature error-handling schemes for the ultimate in data protection.
  • Hardware RAID protection for small business
    Protect your valuable business data with a reliable hardware RAID solution. You can use Pegasus R4 as large storage for a desktop system or as external storage solution for a small server. With 3 TB of storage in RAID 5, you'll have the capacity you need for data and backups with the protection of hardware RAID.
  • Cost-effective expandable storage for home use
    In today's digital world, you consistently acquire and amass large amounts of personal digital media using smart phones and digital cameras, in addition to downloadable digital media acquired through online stores such as iTunes. The Pegasus R4 can protect all these memories meant to last a lifetime from single drive failures, at the same time it's providing data protection, high availability, and high reliability.
  • Flexible backup solution
    Connect Pegasus R4 to your Mac for use with time machine to back up your critical system files, applications, data files, music, pictures, and videos.
  • Ultra-quiet and eco-smart
    Pegasus R4 is RoHS compliant. In simple terms Pegasus R4 is eco-friendly, keeping harmful lead out of the environment and the delicate ecosystems. Sporting a enclosure design, an 80 plus power supply, and active fan management, system noise is never an issue - making Pegasus R4 ideal for desktop, small office environments and or any room in the house.
Promise Pegasus R4 - hard drive array
Hard drive array
Total Array Capacity
8 TB
Max Supported Capacity
8 TB
Thunderbolt
4 (installed) / 4 (max)
Supported Drives
SATA-600
Storage Controller
RAID (SATA 6Gb/s) - RAID RAID 0, 1, 5, 6, 10
Hard Drive
4 x 2 TB HDD - hot-swap
Apple MacOS X 10.6.8 or later
AC 120/230 V - 50/60 Hz
18.7 cm x 23.5 cm x 19.5 cm
4.5 kg
Hard drive array
Chassis
4
Supported Devices / Modules Qty
4
Supported Drives
SATA-600
Storage
8 TB
8 TB
HDD Array External Interface
Thunderbolt
CPU
8011
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
512 MB
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
HDD - hot-swap
4 x 2 TB
Spindle Speed
7200 rpm
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5"
2 x Thunderbolt
Software Included
Drivers & Utilities
RoHS
1 x internal power supply
Max Supported Qty
1
78 Watt
Power Provided
250 Watt
18.7 cm
23.5 cm
19.5 cm
4.5 kg
Limited warranty - 2 years , Limited warranty - power supply - 1 year
