Promethean PRM-35 DLP Short Throw Projector
Quicklinx: 8GC6WS00 Mfr#: PRM-35/33
The ActivBoard System PRM-35 is the consummate attention grabber with a state-of-the-art short-throw projector. From the audience, eyes can't help but face forward.
  • Bright visuals
    With a brightness of 2500 lumens and a reduced brightness of 2100 lumens, the PRM-35 ensures clear, vivid images in various lighting conditions, making it ideal for presentation and multimedia use.
  • High definition clarity
    The PRM-35 boasts a WXGA resolution of 1280 x 800, providing sharp, high-definition images that enhance any presentation.
  • Extended lamp life
    Offering a lamp life cycle of up to 4000 hours in normal mode and 6000 hours in economic mode, the PRM-35 reduces the need for frequent lamp replacements, ensuring reliability and lower maintenance costs.
  • Versatile connectivity
    Equipped with HDMI, S-Video, and VGA video interfaces, the PRM-35 projector supports a wide range of multimedia devices, making it a flexible choice for diverse presentation needs.
  • Secure operation
    The inclusion of a pin code security feature provides peace of mind, ensuring that the projector's settings are safeguarded against unauthorized adjustments.
Promethean PRM-35 - DLP projector - 3D - silver
DLP projector - 720p
3D Capable
Silver
Brightness
2500 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.8 million colours
Bulb type
230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 480i, 1035i, 576i, 575i
230 Watt
30.6 cm x 27.5 cm x 9.7 cm
4.1 kg
3D Capable
Enclosure Colour
Silver
Projector
Brightness
2500 lumens
Brightness (Reduced)
2100 lumens
Contrast Ratio
2000:1
Image Size
127 cm - 279 cm
Projection Distance
0.54 m - 1.22 m
Resolution
WXGA - WXGA (1280 x 800) (native) / 1680 x 1050 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 90 kHz
Bulb type
230 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hungarian, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Romanian, Japanese, Korean, Kazakh
Closed Caption, 16:9 aspect ratio support, Crestron RoomView, 16:10 aspect ratio support, 4:3 aspect ratio support, Direct Power On, Direct Power Off
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-15 / +15
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
1 x HDMI , 1 x network - RJ-45 , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Wireless remote control
1 x VGA cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), PIN code
230 Watt
Software Included
Drivers & Utilities, Crestron RoomView Express
30.6 cm
27.5 cm
9.7 cm
4.1 kg
5 °C
35 °C
Sound Emission
36 dB
32 dB
