Promethean DLP Extreme Short Throw Projector + 1 Yr RTB Warranty
Quicklinx: BPMQWS00 Mfr#: EST-P1
Marketing description is not available.
  • Enhanced connectivity
    With a variety of interfaces including HDMI, S-Video, and VGA, this projector offers versatile connectivity options for both Mac and PC users. Connecting to various sources is seamless and efficient, whether for a high-definition video presentation or a detailed graphical analysis.
  • Optimal viewing experience
    With a brightness of 2500 lumens and a contrast ratio of 2000:1, the projector delivers clear, vibrant images even in well-lit environments. It supports 16:10, 16:9, and 4:3 aspect ratios, ensuring that any content, from movies to presentations, is displayed in its optimal format without compromising on quality.
  • Long-lasting performance
    The projector's lamp life extends up to 4000 hours in normal mode and up to 6000 hours in economic mode, making it a reliable choice for frequent use in presentations and multimedia projects. This longevity, combined with a power consumption of 290 W, offers a balance between performance and energy efficiency.
  • Versatile 3D projection
    Equipped with DLP 3D Ready technology, the projector is capable of delivering immersive 3D presentations and multimedia experiences. This feature adds a dynamic layer to any visual content, whether for educational purposes or entertainment.
  • Comprehensive language support
    The projector's On-Screen Display (OSD) offers an extensive range of languages, including Arabic, Chinese, English, French, and Spanish, among others. This wide language support ensures ease of use for diverse audiences and settings worldwide.
Promethean EST-P1 - DLP projector - 3D - silver
DLP projector
3D Capable
Silver
Brightness
2500 lumens
Contrast Ratio
2000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
220 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 480i, 1035i, 576i, 575i
290 Watt
35.4 cm x 31.9 cm x 15.7 cm
9 kg
3-year warranty
DLP projector
3D Capable
Enclosure Colour
Silver
Projector
Brightness
2500 lumens
Brightness (Reduced)
2200 lumens
Contrast Ratio
2000:1
Image Size
198 cm - 279 cm
Projection Distance
0.39 m - 0.56 m
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
85 Hz x 90 kHz
Bulb type
220 Watt
Bulb life cycle
OSD Languages
Hungarian, Czech, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
Freeze frame, Closed Caption, DLP 3D Ready, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, S-Video
Video Modes
Input Device
External
2 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x network - RJ-45 , 1 x USB , 1 x serial RS-232
Wireless remote control
Security Features
290 Watt
Power Consumption Operational (Standby)
1 Watt
Software Included
Drivers & Utilities
35.4 cm
31.9 cm
15.7 cm
9 kg
Limited warranty - 3 years , Limited warranty - lamp - 3 years / 3000 hours , Technical support - phone consulting - 3 years , Product info support - e-mail consulting - 3 years
5 °C
35 °C
Sound Emission
32 dB
28 dB
