Your basket is empty
Promethean 500PRO Range 78" ActivBoard with Mobile Stand
Quicklinx: 8LW1WS00 Mfr#: ABMS578PEST-UK
The ActivBoard 500 Pro is a state-of-the-art interactive whiteboard with pen and intuitive multi-touch functionality. Designed to foster a true collaborative learning experience, the ActivBoard 500 Pro enables up to four students to work together simultaneously on a task. Images can be easily moved, scaled and rotated with finger touch in conjunction with real life pen tasks such as solving a math equation.
Promethean ActivBoard 578 Pro Mobile System - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
Display
Projector - 1280 x 800
186.8 cm x 90.9 cm x 199 cm
137.2 kg
United Kingdom
Movement Detection Technology
Electromagnetic / capacitive
Movement Resolution
2730 ppi
Performance
200 inches per second
Built-in stereo speakers, built-in 2-ports USB hub, low-glare surface, height adjustable
1 x USB cable - external - 3 m
AC 120/230 V
Microsoft Windows XP SP3 or later, Ubuntu 9.10, Ubuntu 10.04, Microsoft Windows Vista / 7, Apple MacOS X 10.4.11 - 10.6.4, Debian Lenny, Linex Colegios 2010, Linkat 3, ALT Linux
5 years warranty with product registration
186.8 cm
90.9 cm
199 cm
137.2 kg
United Kingdom
Input Device
Wired
USB
Movement Resolution
2730 ppi
Performance
Active Area
162.8 cm x 117.5 cm
Display
Projector
Colour Support
16.7 million colours
Native Resolution
1280 x 800
Image Brightness
2500 lumens
Image Contrast Ratio
2000:1
1 x USB 2.0
Wallmount brackets, 4 x ActivPen, EST-P1 DLP projector
UL, FCC
Power adapter
AC 120/230 V
System Requirements Details
Windows XP/Vista/7 - Core 2 Duo - 2 GHz - RAM 1 GB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.4 - Core 2 Duo - 2 GHz - RAM 512 MB - HD 3 GB , Linux 2 GHz - RAM 1 GB - HD 1.5 GB
Limited warranty - whiteboard - 5 years , Limited warranty - ActivPen - 1 year , Limited warranty - projector - 3 years , Limited warranty - stand - 1 year
8LW1 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
8LW1 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
8LW1 C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
8LW1 C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
8LW1 C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
8LW1 C2G Pro HDMI to VGA Converter In Stock £46.35
