Promethean 300PRO Range 87" ActivBoard with Fixed Stand Projector
Quicklinx: 80R5WS00 Mfr#: ABFS387PDST
The ActivBoard 300 Pro Range is a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. Built in Dual-User capability and with ActivInspire Professional Edition software included means teachers have access to tens of thousands of free lessons and resources at www.PrometheanPlanet.com.
Promethean ActivBoard +2 Fixed 387 PRO - interactive whiteboard - USB
Interactive whiteboard
Wired - USB
Display
Projector - 1280 x 800
211 cm 133 cm
32 kg
Movement Detection Technology
Electromagnetic
Movement Resolution
200 dpi
Built-in stereo speakers, low-glare surface
1 x USB cable
AC 120/230 V
Ubuntu 8.10, Ubuntu 9.04, Microsoft Windows Vista / XP / 7, Mandriva Linux, Ubuntu 8.04, Apple MacOS X 10.4.11 - 10.6.1, Ubuntu 9.10
211 cm
133 cm
32 kg
Input Device
Wired
USB
Electromagnetic
Movement Resolution
200 dpi
Active Area
186.5 cm x 117.5 cm
Display
Projector
Colour Support
16.7 million colours
Native Resolution
1280 x 800
Image Contrast Ratio
500:1
1 x USB - 4 pin USB Type A
4 x ActivPen
1 x USB cable
UL, FCC
Power adapter
AC 120/230 V
Software Included
System Requirements Details
Windows XP/Vista/7 - Pentium 4 - 1 GHz - RAM 512 MB - HD 1.5 GB , MacOS X 10.4.11 - 10.6.1 RAM 512 MB - HD 3 GB
