Pro Signal 2 Meter Display Port DVI-D M Cable
Quicklinx: C1MQWS00 Mfr#: HDHDPORT-001-2M
Length: 2m
29 In Stock
£7.25 ex VAT
£8.70 inc VAT
DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection.
Our DisplayPort to DVI adaptors are the perfect solution for adapting your DisplayPort computer or graphics card to use a DVI monitor/device.
Cables Direct display cable - 2 m
Display cable
Passive converter
Length
2 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
Display cable
Passive converter
Length
2 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
Length: 2m
Brand: Pro Signal
