Prism PI Data original data cabinet range has become a popular selling unit over the years because it meets the all-round, standard requirements of data installation - ease of assembly and access, safety and security in use, and its durability once assembled. In short, as good as value-for-money cabinet range that is available on the market today.
Cabinets can be fitted with a range of options including side panels, solid steel doors, vented glazed doors and vented steel doors all designed to offer the flexibility to meet everyday requirements.
- Networking/Cabling/Broadcast
- 19" Electronic Equipment Housing
- Communication Systems
- IT Systems
- Enclosed glass front door with slam latch lock
- Lockable rear metal door with low level venting
- Vented and lockable side panels
- Raised and vented top cover with cable entry
- Transport castors
- Open base design
- Vertical cable management (800mm wide only)
- Fully adjustable 19" mounting profiles
- Earth bonding kit
- Full range of complenting accessories
- Supplied assembled or in flat pack option
- Multiple door configurations available
- Configurable roof options to cater for overhead cable installations
- Full range of airflow management accessories
- Product Reference: CAB2766
- Prism PI Data 600 - rack - 27U
- Product Type
- Rack
- Rack Size
- 19"
- Height (Rack Units)
- 27U
- 60 cm x 60 cm x 141 cm
- Wheels, key lock
- Product Type
- Rack
- Rack Size
- 19"
- 27U
- 60 cm
- 60 cm
- 141 cm
- Wheels, key lock
