6U 600mm x 450mm Solid Wall Mounted Cabinet
The solid Wall Mounted enclosure has a welded mild steel construction and benefits from 180° door opening.
- Height: 6U
- Width: 600mm
- Depth: 450mm
Product Features and Benefits
Designed with Health and Safety in mind, the metal framed door is fitted with a perspex panel to ensure there are no logistic damages or safety issues in location. The product is designed to be universal in its fixing position and can be installed to allow the door to be opened from left and the right hand side and this can be changed at any time of the product life. The unique fixing method on the rear panel provides a single engineer installation by attaching the frame of the wall cabinet after the fixings have been part installed on the wall. A full range of wall cabinet accessories can be supplied with each range including fan units, shelves and power unit options. As with all of the Prism products the wall mounted enclosures can be supplied in any of the standard colour variants.
- Welded construction
- Lockable perspex front door in a steel surround (over 180° door opening with quick release pins)
- 2 x 19" adjustable mounting profiles
- Cable entry points top, bottom and rear with gland plates
- Vented sides
- Earth bonding kit
- Product Reference: WB6
- Prism PI Wall Box 600 - rack - 6U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Graphite grey
- Rack Size
- 19"
- Height (Rack Units)
- 6U
- Product Material
- Steel
- 60 cm x 45 cm x 33.5 cm
- 12 kg
- Lockable front door, vented
- Product Type
- Rack
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 6U
- 60 cm
- 45 cm
- 33.5 cm
- 12 kg
- Graphite grey
