Never worry about the quality of recorded video Full HD definition of Prestigio Roadrunner CUBE camera ensures that every single detail will be visible and you can be confident about your safety on the road. If an accident occurs you will get all the evidence of your innocence.
Full HD video
Never worry about the quality of recorded video Full HD definition of Prestigio Roadrunner CUBE camera ensures that every single detail will be visible and you can be confident about your safety on the road. If an accident occurs you will get all the evidence of your innocence. -
Built-in Wi-Fi
Pair your Prestigio Roadrunner CUBE with your smartphone via Wi-Fi and increase its possibilities: view, download or delete recorded images and video, update driving information. -
Overheating protection system
Prestigio understands that overheating can damage the battery or the whole device. That is why it implemented an overheating system.
- Prestigio Roadrunner CUBE - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- SD card
- Image Processor
- MSC8328P
- Sensors
- G-sensor
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 2.0 MP
- Effective Sensor Resolution
- Photo: 2.0 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Display
- LCD display - 1.5"
- Incident Detection
- G-Sensor
- Supported Battery
- Li-Polymer rechargeable battery - 150 mAh (included)
- Interface
- USB 2.0
- Black
- 4.5 cm x 4.4 cm x 4.5 cm
- 72 g
- 1-year warranty
- Product Type
- Enclosure Colour
- Black
- Camcorder Sensor Resolution
- 2.0 MP
- Sensor Qty
- 1 CMOS
- Effective Photo Resolution
- 2.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.9"
- Frame Rate (Max Resolution)
- 30 fps
- Image Processor
- MSC8328P
- Sensors
- G-sensor
- Digital Video Format
- H.264
- Image Recording Format
- JPEG
- 1920 x 1080
- Interface
- USB 2.0, Wireless LAN
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Wide-angle lens - wide angle
- Focus Adjustment
- Focus free
- Max View Angle
- 140 degree(s)
Additional Features
- Additional Features
- Audio recording, built-in speaker, Motion Detection Technology, overheat protection
Dashboard Camera Features
- G-Sensor
- Loop recording
Display
- 1.5" LCD display
- Display Format
- 480 x 240
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B)
- Included Accessories
- Car power adapter, USB cable, adhesive mount
- Body Material
- Plastic, metal
- Battery Type
- Lithium polymer - integrated
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- H.264 - 1920 x 1080 p - 30 fps , H.264 - 1280 x 720 p - 30 fps
- Limited warranty - 1 year
- 4.5 cm
- 4.4 cm
- 4.5 cm
- 72 g
- 0 °C
- 45 °C
