FUNCTIONALITY AND SAFETY ON ROAD!
This is a Video recorder which takes protection to a whole new level. It allows you to be safe on the road and receive warnings when unitentionally the vehicle is leaving or crossing its lane.
SUPER HD VIDEO QUALITY
Record highest quality Super HD videos with Ambarella A7 chipset, sensitive Aptina sensor, IS and WDR technology. Highly detailed videos can be used as evidence in legal action, and motor vehicle insurance claims to prove liability.
Warns and protects
RoadRunner 565 makes your trips more safe and protects from accidents that can occur because of negligence or due to somnolence. Video recorder will warn driver in case the vehicle is leaving or crossing its lane. (Lane Departure Warning System (LDWS)
Capture details with 10x zoom
An ultra wide viewing angle of 170 degrees and 10x digital zoom enables you to capture every detail in a nearly panoramic view.
Endless recording
Cyclic recording ensures that camera doesn’t stop recording in case the storage is full. Camera automatically overwrites the oldest files on the memory card, thus enabling it to record indefinitely.
256 MB internal memory allows to save recorded videos on device even without SD card.
Motion Detection
The device features a progressive motion detection technology - the video shooting starts only when detecting a new movement in the frame allowing you to save the card memory for a longer vide
G-Sensor for file protection!
G-Sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won’t be removed by loop recording.
- Prestigio Roadrunner 565GPS - dashboard camera
- Product Type
- Dashboard camera - 1296p
- Memory Card Slot
- microSD card
- Image Processor
- Ambarella
- Sensors
- G-sensor, motion sensor
- Sensor Resolution
- 3.0 MP
- Effective Sensor Resolution
- Photo: 3.0 MP
- Max Video Resolution
- 2304 x 1296
- Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Digital Zoom
- 10x
- Image Stabiliser
- Electronic
- Display
- LCD display - 2"
- Real-Time Locations
- GPS
- Incident Detection
- G-Sensor
- Supported Battery
- Li-ion rechargeable battery - 130 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 9.7 cm x 4.2 cm x 4.2 cm
- 83 g
- 1-year warranty
- Product Type
- Enclosure Colour
- Black
- Camcorder Sensor Resolution
- 3.0 MP
- Sensor Qty
- 1 CMOS
- Effective Photo Resolution
- 3.0 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/3"
- Digital Zoom
- 10x
- Image Processor
- Ambarella
- Image Stabiliser
- Electronic
- Navigation
- GPS receiver
- Sensors
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG
- 2304 x 1296
- Interface
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Max View Angle
- 170 degree(s)
Additional Features
- Built-in Light
- Additional Features
- Built-in speaker, Wide Dynamic Range (WDR), Motion Detection Technology
Dashboard Camera Features
- GPS
- G-Sensor
- Loop recording, motion sensor, Lane Departure Warning System, radar detector
Display
- 2" LCD display
- Display Format
- 640 x 480
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB , HDMI output , Composite video/audio output
Software
- Software
- Drivers & Utilities
- Included Accessories
- Car power adapter, USB cable, suction cup mount
- Battery Type
- Lithium Ion - integrated
- Details
- Battery Life Details
- Video recording - 0.27 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Video Capture
- H.264 - 2304 x 1296 - 30 fps , H.264 - 1920 x 1080 - 30 fps
- Limited warranty - 1 year
- 9.7 cm
- 4.2 cm
- 4.2 cm
- 83 g
- 0 °C
- 45 °C
