Playback videos and view photos on a bright high resolution 2.7" TFT LCD display with ease by using controls. High quality 3MP CMOS image sensor allows the camera to record in 1080p Full HD resolution at 30 frames per second providing smooth and clear image quality.
Full HD quality
A high quality 3MP CMOS image sensor allows the camera to record in 1080p Full HD resolution at 30 frames per second providing smooth and clear image quality. The video quality remains sharp, even in low lighting conditions with the improved super clear night mode technology, so from now on, every single detail will be retained. -
Wide viewing angle
An ultra wide viewing angle of 170 degrees, enables you to capture even more of the scene for a nearly panoramic view, whilst the 4x digital zoom lets you capture every detail. -
Large screen for more visibility
Playback videos and view photos on a bright high-resolution 2.7" TFT LCD display with easy by using controls. -
GPS sensor
The GPS sensor assures speed, acceleration and geolocation. It enables data to be stored together with your video data. -
Electronic image stabilization
With electronic image stabilization your pictures will always be taken with great quality. -
Motion detection and automatic start-up
The device features a progressive motion detection technology - the video shooting starts only when detecting a movement in the frame allowing you to save the card memory for a longer video. Camera recording will start automatically after engine start-up. There is no need to turn on the camera every time you drive somewhere, just start up your car and it will begin to record. -
SOS emergency button and G-Sensor for file protection
In the case of emergency, it allows users to protect the present recording file, simply by pressing and holding the "MENU button". This prevents the current recording from being deleted. G-Sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording. -
Compact and stylish
A stylish device made in a modern design with diamond cut. It's also compact and highly portable - it is almost invisible in the car, but still allows you to be on your guard.
- Product Type
- Dashboard camera - 1080p - widescreen
- Media Type
- Flash card
- Memory Card Slot
- microSD card
- Sensors
- G-sensor
- Sensor Resolution
- 3.0 MP
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Digital Zoom
- 4 x
- Image Stabiliser
- Electronic
- Display
- LCD display - 2.7"
- Real Time Locations
- Non
- Incident Detection
- G-Sensor
- Supported Battery
- 1 x Li-ion rechargeable battery - 130 mAh ( included )
- Interfaces Provided
- HDMI, USB 2.0
- Black
- 8.58 cm x 3.47 cm x 4.38 cm
- 64 g
- 1 year warranty
- Product Type
- Enclosure Colour
- Black
- Camcorder Sensor Resolution
- 3.0 MP
- Camcorder Interpolated Photo Resolution
- 12.0 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/3"
- Digital Zoom
- 4 x
- Image Stabiliser
- Electronic
- Sensors
- G-sensor
- Digital Video Format
- H.264
- 1920 x 1080
- HDMI, USB 2.0
Exposure & White Balance
- Exposure Modes
- Automatic
- White Balance
- Automatic
Lens System
- Wide-angle lens
- Focus Adjustment
- Focus free
- Max View Angle
- 170 degree(s)
Additional Features
- Additional Features
- Built-in speaker, Motion Detection Technology
Dashboard Camera Features
- G-Sensor
- Loop recording, auto on/off, motion sensor
Display
- 2.7" LCD display
- Resolution
- 320 x 240
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- 1 x USB 2.0 , 1 x HDMI
- Memory Card Slot
- microSD card
- Included Accessories
- USB cable, suction cup mount
- Details
- Battery Life Details
- Video recording - 0.2 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Video Capture
- H.264 - 1920 x 1080 - 30 fps
- 1 year warranty
- Service & Support Details
- Limited warranty - 1 year
- 8.58 cm
- 3.47 cm
- 4.38 cm
- 64 g
- 0 °C
- 45 °C
