Prestigio RoadRunner 505 Dashcam with 16Mb Micro SD
PROTECT YOURSELF FROM THE UNEXPECTED ON THE ROAD!
Quicklinx: BYSXWS00 Mfr#: PR-PCDVRR505-16
Type: Dashboard camera
Media Type: Flash card
Video Input: HDMI
Stock Status: Clearance
Hurry, only 3 left in stock!
£39.00 ex VAT
£46.80 inc VAT
The Prestigio RoadRunner 505 combines high quality Full HD video (1920x1080) with lots of advanced features. High resolution display, easy intuitive set-up and its compact size give you greater flexibility to use under various conditions. A 120° wide viewing angle provides an extensive road overview to record in detail what is going on around you. Together with the image stabilization system and a 10 Mpx photo camera your pictures will always turn out in great quality.
Real 1080P FHD Resolution Digital Video Make high quality video in Full HD 1080p with pure sound and crystal clear images to see in detail what is going on around. The optimal combination of a video processor, three-layer glass lens and supersensitive sensor provides a high image quality even in low light conditions.
Motion Detection Portable and convenient, the device features a progressive motion detection technology - the video shooting starts only when detecting a new movement in the frame. Thus it allows you to save the card memory for a longer video.
Wide viewing angle RoadRunner 505 is equipped with FULL HD-camera with a 120° wide viewing angle. Such an angle is optimal because it provides an extensive road overview, prevents image distortion and does not reduce the object detalization level.
High resolution display It is very easy to customize the image clarity, contrast and color settings with big 2.0-inch TFT screen and LED backlight modules. Adjust the video recording quality as well as all additional parameters and operation modes with the user-friendly control panel.
  • Real 1080P FHD resolution digital video
  • Electronic image stabilization
    Trembling is not a problem now. With electronic image stabilization your pictures will always turn out in great quality.
  • Motion detection
  • Wide viewing angle
  • High resolution display
Prestigio Roadrunner 505 - dashboard camera
Dashboard camera - 1080p - widescreen
Image Processor
NT9620
Sensor Resolution
5.0 MP
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Digital Zoom
3x
Image Stabiliser
Electronic
Display
LCD display - 2"
Supported Battery
1 x Li-ion rechargeable battery - 450 mAh (included)
HDMI
8.2 cm x 2 cm x 5.5 cm
90 g
Enclosure Colour
Camcorder Sensor Resolution
5.0 MP
Sensor Qty
1 CMOS
Camcorder Interpolated Photo Resolution
10.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2"
Digital Zoom
3x
Image Processor
NT9620
Image Stabiliser
Electronic
Digital Video Format
AVI, MJPEG
HDMI
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Wide-angle lens
Focus Adjustment
Focus free
Max View Angle
120 degree(s)
Additional Features
Additional Features
Built-in speaker, Motion Detection Technology
Dashboard Camera Features
Loop recording, auto on/off
Display
2" LCD display
Display Format
960 x 240
Display Form Factor
Folding
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , HDMI output
Car power adapter, USB cable, suction cup mount
Body Material
Plastic
Battery Type
Lithium Ion - integrated
Details
Memory / Storage
Supported Memory Cards
SD Memory Card, SDHC Memory Card
Video Capture
AVI - 1920 x 1080 - 25 fps , AVI - 1280 x 720 - 60 fps , AVI - 640 x 460 - 60 fps
8.2 cm
2 cm
5.5 cm
90 g
-5 °C
Video Input: HDMI
Brand: Prestigio
Price Range Ex VAT: 0 - 50
