Prestigio RoadRunner 140 Full HD Dashcam
Quicklinx: D8R0WS00 Mfr#: PR-PCDVRR140
Type: Dashboard camera
Media Type: Flash card
Optical Zoom: 4
Supported Memory Cards: microSD Card, microSDHC Card, SDHC Memory Card, SD Memory Card
Video Input: USB 2.0
  • microSD Card
  • SDHC Memory Card
  • microSDHC Card
More than 50 In Stock
£24.99 ex VAT
£29.98 inc VAT
With the Prestigio RoadRunner 140 you will always be sure that all the important events on the road are captured. 110 degrees viewing angles, 4 layer glass lens and 4x digital zoom ensures clear and detailed video, whilst the 12 MP camera takes vivid and light pictures. It is extremely compact and light, so it is almost invisible in the car and easy to transport even in a small pocket.
  • High-quality video
    You will get the perfect video of your trip. High quality is optimal for car video registers because it ensures clear images and makes details visible. Pure sound will be a good advantage as well.
  • Endless recording
    Cyclic recording ensures that your camera does not stop recording when the storage is full. The camera automatically overwrites the old files on the memory card, thus enabling it to record indefinitely.
  • Bright screen
    LCD screen gives an opportunity to adjust image options like clarity, contrast and color settings.
  • Capture details
    Capture the wide field of view with 110° viewing angles and get the advantages of high optical quality of pictures taken by a 12 MP camera with a 4 layer lens.
  • G-sensor for file protection
    A G-sensor traces sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files will not be removed by loop recording.
  • Motion detection
    The device features progressive motion detection technology. In this mode the video shooting, starts only when detecting a movement in the frame, allowing you to reserve the memory card for a longer video. This function might be very useful during long-term parking.
Prestigio Roadrunner 140 - dashboard camera
Dashboard camera
Memory Card Slot
microSD card
Sensors
G-sensor, motion sensor
Internal Storage
128 MB
Sensor Resolution
1.0 MP
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens
Digital Zoom
4x
Display
LCD display - 1.5"
Incident Detection
G-Sensor
Supported Battery
Li-Polymer rechargeable battery - 200 mAh (included)
USB 2.0
6.5 cm x 4.1 cm x 4.1 cm
37.2 g
1-year warranty
Dashboard camera
Enclosure Colour
Camcorder Sensor Resolution
1.0 MP
Sensor Qty
1 CMOS
Camcorder Interpolated Photo Resolution
12.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/4"
Frame Rate (Max Resolution)
25 fps
Digital Zoom
4x
Sensors
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1920 x 1080
USB 2.0
Lens System
Wide-angle lens
Max View Angle
110 degree(s)
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker
Dashboard Camera Features
Incident Detection
G-Sensor
Loop recording, motion sensor
Display
1.5" LCD display
Display Format
480 x 240
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 (5 pin Micro-USB Type B)
Car power adapter, suction cup mount
Body Material
Plastic
Battery Type
Lithium polymer - integrated
Details
Battery Life Details
Video recording - 0.66 hours
Memory / Storage
Memory Card Slot
microSD card
Internal Storage
128 MB
Memory Card Included
No
Memory Card Max Supported Size
32 GB
Video Capture
AVI - 1920 x 1080 - 25 fps , AVI - 1280 x 720 - 30 fps , AVI - 640 x 480 - 30 fps
Limited warranty - 1 year
6.5 cm
4.1 cm
4.1 cm
37.2 g
45 °C
Optical Zoom: 4
Supported Memory Cards: microSDHC Card
Supported Memory Cards: SDHC Memory Card
Supported Memory Cards: SD Memory Card
HD Support: 1080p
Brand: Prestigio
