Prestigio Prestigio RoadRunner 560GPS DashCam
Quicklinx: C7YRWS00 Mfr#: PCDVRR560GPS-16
Extra Large Screen, Extra Visibility!
The Prestigio RoadRunner 560 has a bright and large 3" screen for ultimate video recording experience. It is able to record ever single detail thanks to its panaromic view with 170° viewing angle. The Prestigio RoadRunner 560 is an invaluble companion at night with improved performance in low-light environment.
Key Features
EXTRA VISIBILITY: Watch your videos and photos on extra large and bright 3-inch TFT LCD screen.
VIDEO QUALITY: Full HD video quality with Ambarella A7 chipset, sensitive Aptina sensor, 170° viewing angle, IS and WDR technology.
GPS: The GPS sensor assures that speed, acceleration and geolocation data are stored together with your video data.
ELECTRONIC IMAGE STABILIZATION: Trembling is not a problem. With electronic image stabilisation your pictures will always turn out in great quality.
WIDE DYNAMIC RANGE: Records greater scene details in poor lighting conditions.
  • Full HD video quality
    Record crystal-clear videos in Full HD quality with Ambarella A7 chipset and sensitive Aptina sensor. Videos will stay clear and sharp even in low light conditions and can be used as evidence if needed. No matter it is day or night, RoadRunner 560 can perfectly record all the time thanks to wide dynamic range technology and night vision mode.
  • Large screen
    Large and bright LCD screen for live view and playback makes it easier than ever to gather reliable evidence and examine events.
  • Wide viewing angle
    Records in wide 170° viewing angle to capture every detail. It provides an extensive road overview and prevents image distortion.
  • Wide dynamic range
    High-quality camera lens will automatically adjust to light conditions to capture all the details including license plates, in both day and night.
  • Motion detection
    The device features a progressive motion detection technology - the video shooting starts only when detecting a new movement in the frame allowing you to save the card memory for a longer video.
  • G-Sensor for file protection
    G-Sensor senses sudden acceleration, braking and collisions in order to automatically capture and protect critical footage surrounding an accident. Through this function the important files won't be removed by loop recording.
Included
Car video recorder
Display Size
3.0" (640x360 px)
Image Sensor
4.0 MP Aptina CMOS | 1/2.5"
Digital Signal Processor
Ambarella A7LA30
Digital Zoom
10x
Video Codec
H.264
Video | Photo Resolution
1920x1080p@30 fps, 1920x1080p (HDR) @30 fps, 1280x720p@60 fps | 4 MP
Video | Picture Format
MP4 | JPG
Viewing Angle
170 degree
Lens
Aperture: 2.0 mm | Focal Length: 3.2 mm
Other features
Wide Dynamic Range, Motion detection, Radar detector, G-Sensor
GPS sensor
Memory Expansion
up to 64 GB (SDXC, MicroSD)
Microphone | Speaker
built-in
Power Source
Rechargerble Li-on battery (130 mAh) or car charger with DC 5V 1A output
Operation Temperature
0 ° - 45 °?
HDMI, mini USB 2.0
Dimensions | Weight
96.2x52.8x26.5 mm | 72 g
Included
Car video recorder
USB cable
Display Size
3.0" (640x360 px)
Image Sensor
Ambarella A7LA30
Digital Zoom
10x
Video Codec
H.264
MP4 | JPG
Viewing Angle
170 degree
Lens
Other features
GPS sensor
Memory Expansion
built-in
Power Source
0 ° - 45 °?
HDMI, mini USB 2.0
Dimensions | Weight
