Prestigio PBS7 Universal Tablet and Phone Bluetooth Speaker with Microphone and Stand
Quicklinx: C9K4WS00 Mfr#: PBS7
Get inspired by the extreme quality of sound with the compact stylish new Prestigio Universal Tablet Stand with BT Wireless Speaker! The stand function makes watching Video streaming both cosy and comfortable and the built-in microphone facilitates comfortable Skype calls and video conferences. Enjoy Real Sound together wherever you are - whether you’re going to the beach, camping or simply to your house, you can enjoy your music wirelessly up to 50 m. Want your speaker to last for a longer time – so more music? Don’t worry. The rechargeable battery lasts up to 6 hours on a single charge. Do you want to leave your device inside while the speaker goes out? No problem. You can play music up to 10 m away from your Bluetooth device. Enjoy simplified Bluetooth® connectivity with NFC. Just touch NFC logos to: power the speaker on, activate Bluetooth®, pair devices and stream music. Rechargeable battery 1150 mAh allows to charge your Smartphones and Tablet PCs.
Prestigio PBS7 - speaker - for portable use - wireless
Speaker - for portable use
Speaker Type
Active
Continuous Power
6 Watt
Frequency Response
20 - 20000 Hz
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - 3 Watt - 20 - 20000 Hz - 4 Ohm - active
Silver
Power Options
USB charging
Speaker battery rechargeable
9 cm x 5.29 cm x 20 cm
440 g
Hands-Free Function
Enclosure Colour
Silver
Speaker System
Speaker Type
Active
Continuous Power
6 Watt
Frequency Response
20 - 20000 Hz
Signal-To-Noise Ratio
70 dB
Amplifier
Integrated
Bluetooth, Near Field Communication (NFC)
Transmission Range
10 m
Controls
Power on/off, volume, play/pause
Additional Features
Built-in stand
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 3 Watt - 20 - 20000 Hz CFR - 4 Ohm - active
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 pin USB Type A (power only))
Carrying pouch, audio cable, power adapter
Power Source
Options
USB charging
Rechargeable
Capacity (Ah)
1150 mAh
Run Time (Up To)
6 hour(s)
9 cm
5.29 cm
20 cm
440 g
