Monitor your car 24/7 with the PRAKTICA 10GW Car Camcorder. Equipped with Full HD video and a high quality wide angle lens, you can be assured that everything will be caught on camera.
Whether you're driving or stationary, the built in motion detection will pick up vibrations surrounding the car and will automatically begin filming. Installed with GPS for real time location tracking, simply download videos to your smartphone or tablet via Wi-Fi and share footage within minutes.
Additional features include: an easy to use touch screen, lane departure and forward collision warnings, speed limit alerts and a dual charger so that you can power your car cam and smartphone or tablet at the same time.
Bundle includes 32GB MicroSD Card and Carry case!
- PRAKTICA 10GW - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- microSD card
- Sensors
- Motion sensor, 3-axis accelerometer
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 2.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens 3.37 mm f/2.0
- Focus Adjustment
- Focus free
- Min Focus Distance
- 1.5 m
- Display
- LCD display - 2.7"
- Real-Time Locations
- GPS / GLONASS
- Incident Detection
- G-Sensor
- Supported Battery
- Li-Polymer rechargeable battery - 470 mAh (included)
- Interface
- USB 2.0
- 8 cm x 3 cm x 5.1 cm
- 82 g
- 2-year warranty
- Product Type
- Sensor Resolution
- 2.0 Megapixel
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.7"
- Frame Rate (Max Resolution)
- 30 fps
- Sensors
- Digital Video Format
- H.264, MOV
- 1920 x 1080
- Interface
- USB 2.0, Wireless LAN
Exposure & White Balance
- Light Sensitivity
- ISO auto
- White Balance
- Automatic
- Max Shutter Speed
- 1/2 sec
- Min Shutter Speed
- 1/2000 sec
Lens System
- Wide-angle lens 3.37 f/2.0
- Focus Adjustment
- Focus free
- 1.5 m
- Max View Angle
- 140 degree(s)
Additional Features
- Additional Features
- Built-in speaker
Dashboard Camera Features
- GPS / GLONASS
- G-Sensor
- Loop recording, date and time stamp, Safety Camera alerts, motion sensor, Driver Fatigue alert, Speed Alarm, Lane Departure Warning System, Forward Collision Warning System
Display
- 2.7" LCD display
- Display Form Factor
- Built-in
- Touch Screen
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB (mini-USB)
- Included Accessories
- Car power adapter, suction cup mount
- Battery Type
- Lithium polymer - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 32 GB
- Image Storage
- JPEG 1920 x 1080
- Video Capture
- H.264 - 1920 x 1080 p - 30 fps
- Limited warranty - 2 years
- 8 cm
- 3 cm
- 5.1 cm
- 82 g
- 0 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 80 °C
- 20 - 70%
