Praktica 10GW Wireless GPS Car Dash Cam Kit inc 32GB SD Card & Case
Quicklinx: CS2FWS00 Mfr#: 10GW 32GBMSDCASE
Monitor your car 24/7 with the PRAKTICA 10GW Car Camcorder. Equipped with Full HD video and a high quality wide angle lens, you can be assured that everything will be caught on camera.
Whether you're driving or stationary, the built in motion detection will pick up vibrations surrounding the car and will automatically begin filming. Installed with GPS for real time location tracking, simply download videos to your smartphone or tablet via Wi-Fi and share footage within minutes.
Additional features include: an easy to use touch screen, lane departure and forward collision warnings, speed limit alerts and a dual charger so that you can power your car cam and smartphone or tablet at the same time.
Bundle includes 32GB MicroSD Card and Carry case!
PRAKTICA 10GW - dashboard camera
Dashboard camera - 1080p
Memory Card Slot
microSD card
Sensors
Motion sensor, 3-axis accelerometer
Wireless Interface
Wireless LAN
Sensor Resolution
2.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens 3.37 mm f/2.0
Focus Adjustment
Focus free
Min Focus Distance
1.5 m
Display
LCD display - 2.7"
Real-Time Locations
GPS / GLONASS
Incident Detection
G-Sensor
Supported Battery
Li-Polymer rechargeable battery - 470 mAh (included)
USB 2.0
8 cm x 3 cm x 5.1 cm
82 g
Sensor Resolution
2.0 Megapixel
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.7"
Frame Rate (Max Resolution)
30 fps
Sensors
Digital Video Format
H.264, MOV
1920 x 1080
USB 2.0, Wireless LAN
Exposure & White Balance
Light Sensitivity
ISO auto
White Balance
Automatic
Max Shutter Speed
1/2 sec
Min Shutter Speed
1/2000 sec
Lens System
Wide-angle lens 3.37 f/2.0
Focus Adjustment
Focus free
Min Focus Distance
1.5 m
Max View Angle
140 degree(s)
Additional Features
Additional Features
Built-in speaker
Dashboard Camera Features
Real-Time Locations
GPS / GLONASS
Incident Detection
G-Sensor
Loop recording, date and time stamp, Safety Camera alerts, motion sensor, Driver Fatigue alert, Speed Alarm, Lane Departure Warning System, Forward Collision Warning System
Display
2.7" LCD display
Display Form Factor
Built-in
Touch Screen
Microphone
Microphone Operation Mode
Mono
Connector Type
USB (mini-USB)
Car power adapter, suction cup mount
Battery Type
Lithium polymer - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card Included
No
Memory Card Max Supported Size
32 GB
Image Storage
JPEG 1920 x 1080
Video Capture
H.264 - 1920 x 1080 p - 30 fps
8 cm
3 cm
5.1 cm
82 g
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
80 °C
20 - 70%
