Polycom Wireless SoundStation2
Quicklinx: 3R1ZWS00 Mfr#: 2200-07800-102
Now there's a conference phone without cords that gives you the freedom to conference anywhere team collaboration is important - even in rooms where there are no phone lines.
With superior voice quality to the award winning SoundStation, proven 2.4 GHz wireless technology, added security of voice encryption, up to 24 hours of talk time, and the ability to dial through a cell phone, the SoundStation2W is the new standard for everyday conferencing.
SoundStation2W delivers voice quality that is twice as loud and provides twice the microphone sensitivity as the original SoundStation enabling clearer natural, two-way conversations. The secure and proven 2.4 GHz platform provides simple and robust wireless capability with any analog phone line. SoundStation2W is also the first phone that bridges cell phone convenience and Polycom voice quality. By connecting with a standard headset cable, users can dial through cell phones or transfer between handset and conference phone mode. With reliable 150 foot wireless roaming from the base station, wireless frequency hopping to avoid interference, and a long lasting Lithium-ion battery, the SoundStation2W truly meets today's needs for excellent voice quality and usage flexibility.
The SoundStation2W - designed to be used where you need it, because the conference room isn't enough!
  • Acoustic Clarity technology
    Allow simultaneous natural conversation - the industry's best full duplex.
  • Proven and secure wireless
    2.4 GHz WDCT technology comes with voice encryption for added security.
  • Long lasting battery
    Charge once a week and go! Up to 24 hours talk time Lithium-ion battery with portable charger.
  • Unparalleled flexibility
    Cell phone connector is for a mode of conferencing when there are no phone lines available.
  • Easy to use and install
    Work like other Polycom conference phones, compatible with any analog line.
Poly - Polycom SoundStation2W EX - cordless conference phone with caller ID
Cordless conference phone with caller ID
Cordless Phone Standard
DECT
Speakerphone
Yes (digital duplex)
Caller ID
Call Services
Caller ID, Call Hold
Display
LCD display - monochrome - Yes
1-year warranty
Phone Features
DECT
Call Services
Caller ID Type
Caller ID
Max Handset Operating Distance
45 m
Dialer Type
Keypad
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Conference button, mute button, hold button, auto redial button
Volume Control
Firmware Upgradable
Additional Features
Noise reduction, on-hook dialling
Phone Memory
Phone Directory Capacity
20 names & numbers
Display
Display Information
Battery status, signal strength
Backlit
Cellular phone connection headset jack / sub-mini-phone 2.5mm , USB / mini-USB Type B , 2 x microphone jack , Audio line out / RCA
Placing / Mounting
Wall-mountable, table-top
Power adapter
UL, cUL, ICES-003, FCC Part 15.247, FCC Part 68
Power adapter - external
1 x battery
Rechargeable - Lithium Ion
Included Qty
1
Talk Time
Up to 1440 min
Standby Time
Up to 160 h
Recharge Time
8 hour(s)
Audible Battery Alert
Dimensions & Weight (Base)
31.1 cm
36.8 cm
6.4 cm
0.86 kg
Limited warranty - 1 year
