Polycom VVX 1500 D Dual Stack SIP&H.323 Business Media Phone
Quicklinx: 912XWS00 Mfr#: 2200-18064-025
The Polycom VVX 1500 D dual stack business media phone unifies video, voice and applications capabilities in a simple-to-use personal communication solution. With its unique touch screen interface, the VVX 1500 D makes video calls as simple as using a desktop phone. Its large display and ease of use make the VVX 1500 D an ideal productivity tool for today's busy executives and professionals, whether they are in office, retail, professional services, or healthcare environments.
The Polycom VVX 1500 D includes an integrated camera and delivers easy and instant business-grade video calling with a simple touch of the screen. With native H.323 support, it connects easily with all standards-based H.323 video conferencing and telepresence systems, such as the Polycom HDX series, and real-time media conference platforms, such as the Polycom RMX series, enabling mass adoption of business-grade video in the enterprise. The VVX 1500 D has multiple adjustable elements including camera tilt, base height and screen angle to suit the environment and a user's preferences.
  • One-touch personal video device
  • Business information at-a-glance
    The Polycom VVX 1500 D business media phone features an open API and WebKit-based full browser that enable third-party developers to create applications that integrate the VVX 1500 D with business systems such as UC, customer relationship management (CRM), and other vertical business applications. The VVX 1500 D comes with a web service called Polycom My Info Portal, through which customers can select to receive personalized web content, such as stock prices, weather, and news.
  • Feature-rich phone with Polycom HD Voice
    The Polycom VVX 1500 D is equipped with all of the capabilities of a full featured SIP IP phone including: six lines, Polycom HD Voice technology, a Gigabit Ethernet switch that supports PoE, and a host of voice telephony functions. These features can be accessed via the buttons on the front of the phone or by simply touching the large color display. Use of the voice telephony functionality requires integration with a Polycom certified SIP call control platform.
  • Flexible, future-proof UC solution
    With H.323 and SIP dual stack support, the VVX 1500 D business media phone delivers a future-proof UC endpoint that integrates voice, video and applications into an overall UC solution. Enterprises can implement the VVX 1500 D with existing H.323-based video networks today with the flexibility to integrate it with a SIP IP telephony call control platform in the future.
Poly VVX 1500 D - IP video phone - 3-way call capability
IP video phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
H.323, SIP
Voice Codecs
G.722, G.729ab, G.711u, G.711a
Lines Supported
Multiline
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Display
LCD display - colour - Yes
Display Features
LCD touch screen, screen saver
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
1-year warranty
IP video phone
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Menu Operation
Volume Control
Ringer Control
Additional Functions
Call timer, Web browser
Additional Features
Noise reduction
IP Telephony
Main Features
VoIP
VoIP Protocols
H.323, SIP
Voice Codecs
Video Codecs
H.263, H.263+, H.264
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
IP, TCP, TFTP, UDP, HTTP, DNS
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (ECN), HD Voice
Network Features
Network Address Translation (NAT)
Display
Display Location
Base
Diagonal Size
7"
Backlit
Phone Camera
Frame Rate at Max. Resolution
30 fps
Camera Resolution
352 x 288 (CIF)
Headset jack , USB / 4 PIN USB Type A
Hearing Aid Compatible
Network cable
Power adapter
VCCI Class B ITE, CISPR 22 Class B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/NZS 60950-1, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC CFR47 Part 15 B
Power adapter - external
Dimensions & Weight (Base)
25 cm
21 cm
38 cm
2.5 kg
Limited warranty - 1 year
