Polycom VVX 1500 6-line Business Media Phone
Quicklinx: 912TWS00 Mfr#: 2200-18061-025
The Polycom VVX 1500 unifies voice, video and applications capabilities into a simple-to-use business media phone. With its unique touch screen interface, the VVX 1500 makes video calls as simple as using a phone. Its large display and ease of use make the VVX 1500 an ideal all-in-one productivity tool for today's busy executives and professionals, whether they are in office, retail, professional services, or healthcare environments.
  • Feature-rich phone with Polycom HD Voice
    The Polycom VVX 1500 is equipped with all of the capabilities of a full featured Polycom SoundPoint IP phone including: six lines, Polycom HD Voice, a Gigabit Ethernet switch that supports PoE, and a host of rich telephony functions. These features can be accessed via the buttons on the front of the phone or by simply touching the large color display.
  • One-touch personal video system
    The Polycom VVX 1500 includes an integrated camera and delivers business-grade video calling with a simple touch of the screen. The phone has multiple adjustable elements including camera tilt, base height and screen angle to suit the environment and a user's preferences for personalized eye-to-eye visual communications.
  • Business information at-a-glance
    The Polycom VVX 1500 features an open API and micro-browser that enable third-party applications developers to integrate the VVX 1500 with business applications such as unified communications, customer relationship management (CRM), and appointment management systems. The touch-screen user interface of the VVX 1500 includes a menu screen on which developers can place icons for users to touch and launch their applications.
Poly VVX 1500 - IP video phone - 3-way call capability
IP video phone
Main Features
Integrated Ethernet switch
VoIP Protocols
SIP
Voice Codecs
G.722, G.729ab, G.711u, G.711a
Lines Supported
Multiline
Speakerphone
Yes (digital duplex)
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
Display
LCD display - colour - Yes
Display Features
LCD touch screen, screen saver
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
1-year warranty
IP video phone
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Menu Operation
Volume Control
Ringer Control
Additional Functions
Call timer, Web browser
Additional Features
Noise reduction
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP
Voice Codecs
Video Codecs
H.263, H.263+, H.264
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP, static
Power Over Ethernet (PoE) Support
Network Protocols
IP, TCP, TFTP, UDP, HTTP, DNS
Network Ports Qty
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (ECN), HD Voice
Network Features
Network Address Translation (NAT)
Display
Display Location
Base
Diagonal Size
7"
Backlit
Phone Camera
Frame Rate at Max. Resolution
30 fps
Camera Resolution
352 x 288 (CIF)
Headset jack , USB / 4 PIN USB Type A
Hearing Aid Compatible
Network cable
Power adapter
VCCI Class B ITE, CISPR 22 Class B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/NZS 60950-1, CCC, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, FCC CFR47 Part 15 B
Power adapter - external
Dimensions & Weight (Base)
25 cm
21 cm
38 cm
2.5 kg
Limited warranty - 1 year
