Polycom VSX 5000
Polycom VSX 5000
Quicklinx: 5DPGWS00 Mfr#: 2200-22550-102
Ideal for smaller conference spaces, the entry-level Polycom VSX 5000 set-top system brings market-leading video and audio quality within an affordable price. A real space-saver, it sits conveniently on top of TVs, high-resolution plasma screens, or LCD displays. You can easily add a peripheral, dual monitors, and audio-only callers through ISDN or the SoundStation VTX 1000. In fact, the VSX 5000 gives you multiple ways of dialing conference attendees and employing various types of content.
The VSX 5000 is also well-suited for educational resource rooms where smaller groups of students meet with a remote educational specialist, and remote medical clinics that deliver specialist care to patients hundreds of kilometers from home.
When you're ready to upgrade your meeting room environment even further, you can take advantage of Polycom's SoundStation VTX 1000 integration, giving users the ability to dial a video conference from their conference phone. This also saves space on the conference table, since the SoundStation VTX 1000 also acts as the stereo microphone as well as a standalone conference phone. Plus, dedicated stereo audio outputs enable easy implementation of Polycom's StereoSurround technology, for sound that is as natural as being there.
  • Superior, natural sound
    Polycom StereoSurround delivers crisp, natural voice clarity - even when multiples parties are speaking simultaneously - by using dual channel, Siren 14 technology.
  • Outstanding video
    It is a premium quality video at any bandwidth with smooth natural motion and sharp, clear images. It also employs standard-based H.264 compression and Pro-Motion video for optimal viewing.
  • Multimedia made easy
    Show high resolution images, movies or presentations in your meetings while also sharing video. And, you can share PC content cable-free using Polycom's unique People+Content IP technology.
  • Network friendly
    Features include video and audio error concealment, UPnP, NAT and Closed Captioning support, embedded encryption, plus web streaming.
Poly - Polycom VSX 5000 - video conferencing device
Video conferencing device
30.1 cm x 25.5 cm x 13.3 cm
4.4 kg
Digital Signaling Protocol
H.323, H.281
Video Input
Digital video camera
Video Output
Codec board
Audio Input
Microphone
Input Device
Remote control (wireless)
Modem
Modem (digital)
Network adapter - Ethernet, Fast Ethernet
1-year warranty
30.1 cm
25.5 cm
13.3 cm
4.4 kg
Modem
Modem (digital) - integrated
H.323, H.281
Video Input
Digital video camera (colour) - integrated
Video Output
Codec board - integrated
Supported Display Graphics
VGA (640x480), XGA (1024x768), SVGA (800x600)
Analogue Video Signal
RGB, S-Video (NTSC, PAL)
Audio Input
Microphone - external
Input Device
Remote control
Wireless
Network adapter
Wired
Network / Transport Protocol
TCP/IP, UDP/IP
DHCP support, ARP support, manageable
2 x display / video - S-video output - 4 pin mini-DIN , 1 x display / video - VGA output , 1 x management - RS-232 , 2 x audio - line-out - RCA x 2 , 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-In - RCA x 2 , 1 x microphone - input , 1 x display / video - S-video input
Power supply - internal
80 Watt
Limited warranty - parts and labour - 1 year , New releases update - 1 year
15 - 80%
