Polycom Trio Visual+
Quicklinx: BRJ8WS00 Mfr#: 2200-13339-001
Expand your RealPresence Trio to add visual collaboration with the Polycom RealPresence Trio Visual+ accessory. The Visual + accessory is an optional device that allows you to easily transform RealPresence Trio audio calls into multimedia collaboration experiences.
  • Share your ideas and concepts
    Polycom RealPresence Trio is an ideal communication solution for every meeting space that needs a best-in-class audio experience. But what if you want to share your ideas and concepts visually? With the RealPresence Trio Visual+, you can easily share presentations, spreadsheets, photos and even multimedia videos with everyone in the room, with remote participants, or both simultaneously; all while using the tools you are already familiar with: your own PC, tablet or smartphone. Connect with ease, using Polycom, Microsoft, BroadSoft or Cisco platforms, and share your most powerful visuals, today.
  • See and experience their reactions
    Ever wonder if your ideas are making the impact you desire? The RealPresence Trio Visual+ also supports high definition 1080p video from a simple USB camera. See your audience and experience their emotions right as they happen. Visual+ provides complete visual collaboration on a budget that is perfect for huddle rooms and small-to midsize spaces.
  • Empowers administrators
    RealPresence Trio Visual+ is quick to deploy with simple plug-and-play connections: HDMI for your display, USB for camera and Power-over-Ethernet (PoE) for electricity. That's it! With its small footprint, it can easily be mounted out of view, and with native support for Microsoft Lync 2013, Skype for Business and all major SIP platforms, it provides future-proof deployment. The Polycom RealPresence Trio with Visual+ is the perfect group collaboration solution for teams of any size, and they are priced right for mass deployment across your entire organization.
Poly RealPresence Trio Visual+ Accessory - video conferencing device
Video conferencing device
11.5 cm x 11.5 cm x 2.8 cm
770 g
1-year warranty
11.5 cm
11.5 cm
2.8 cm
770 g
Video Output
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Wired
Power over Ethernet (PoE), IPv4 support
IEEE 802.3af
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T (PoE) - RJ-45 , 1 x audio - output - mini-phone stereo 3.5 mm , 2 x USB 2.0 - 4 pin USB Type A , 1 x audio / video - HDMI - 19 pin HDMI Type A
1 x network cable - 4.5 m , 1 x HDMI cable - 1.8 m
Mounting Kit
Included
CISPR 22 Class A, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, VCCI Class A, CAN/CSA-C22.2 No. 60950-1
Limited warranty - 1 year
10 - 90% (non-condensing)
