Simple and intuitive to use, Poly CCX Series helps users get down to work immediately. Block out the office chaos and focus. Teams will be extremely productive all the time.
- Poly CCX 600 for Microsoft Teams - VoIP phone
- Product Type
- VoIP phone
- VoIP Services
- Skype
- Software Certification
- Certified for Microsoft Teams
- Speakerphone
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Display
- LCD display - colour - Yes
- Display Features
- Touch screen
- Compatible Software
- Microsoft Teams, Skype for Business
- Product Type
- VoIP phone
Phone Features
- Operating System
- Android 9.0 Pie
- VoIP Services
- Skype
- Wireless Interface Provided
- Wi-Fi / Bluetooth
- Call Services
- Dialer Location
- Base
- Speakerphone
- Additional Functions
- Call timer, Web browser
IP Telephony
- VoIP
- Power Over Ethernet (PoE) Support
Display
- Display Location
- Base
- Diagonal Size
- 7"
- Backlit
- Touch screen
- Connections
- USB Type-C , USB
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FMCK 046935 Condition: Customer return - item has been opened but is in excellent condition |
£65.58 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
