Power up productivity for office workers with the Voyager 4200 UC Series Bluetooth wireless headsets. Connecting is seamless - smartphone or computer. Outstanding audio, freedom to roam.
Escape the desk
Give office workers flexibility and hands-free productivity with up to 30 meters / 98 feet of Bluetooth wireless range with the included BT600 USB adapter. -
Connectivity options
Easy connectivity options for your different communication needs: BT600 USB Bluetooth adapter to connect to your PC and directly to the mobile phone via Bluetooth . -
No need for battery anxiety
Keep your headset fully charged using a desktop charging stand. You can also extend the battery life by using it corded, with audio over USB mode. -
Smart sensors
Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free. -
Easy management via Poly Lens
Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software. -
Certified for Microsoft Teams
Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
- HP Poly - for Microsoft Teams - wireless headset system base for Bluetooth headset
- Product Type
- Wireless headset system base
- Intended For
- Bluetooth headset
- Package Content
- Wireless headset system base, USB cable, telephone interface cable, power adapter
- Compatible Software
- Microsoft Teams
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Designed For
- Poly Voyager 4320; Voyager 4300 UC Series 4310; Voyager Focus 2 Office; 2 UC
- Product Type
- Intended For
- Bluetooth headset
- Microsoft Teams
- Package Content
- Limited warranty - 2 years
- Designed For
- Poly Voyager 4320 , Poly Voyager 4300 UC Series 4310 , Poly Voyager Focus 2 Office , Poly Voyager Focus 2 UC
