Poly VVX450 Wall Mount Bracket
Quicklinx: HS68WS00 Mfr#: 89D25AA
Hurry, only 3 left in stock!
£12.31 ex VAT
£14.77 inc VAT
Discover a solution for your AV setup with the HP Inc. Poly bracket. Designed with security and versatility in mind, this wall-mountable bracket ensures your AV equipment is safely attached to the wall, providing a clutter-free environment. Its adaptable design makes it suitable for a wide variety of AV furniture, offering flexibility for different setups. Whether for home or professional use, this bracket is engineered to meet your needs, simplifying installation and maximizing space.
  • Efficient mounting
    Designed for ease and flexibility, this wall-mountable bracket allows for quick installation, ensuring your AV equipment is securely attached to the wall without hassle.
  • Versatile design
    The bracket's adaptable design supports a wide range of AV furniture, making it a perfect fit for various setups and environments.
Poly bracket
Bracket - wall-mountable
AV Furniture
Bracket
Placing / Mounting
Wall-mountable
Dimensions & Weight Details
15 cm x 8 cm x 20.5 cm / 430 g
Brand: Poly
