Poly VVX 450 Desktop Phone PoE - Excluding PSU
Quicklinx: HM5BWS00 Mfr#: 8B1L7AA#AC3
More than 50 In Stock
£132.87 ex VAT
£159.44 inc VAT
When you want the best small business 12-line phone system for your money, the VVX 450 is full of good surprises. Handle high volume calls easily with the sleek, color display - and be confident conversations will always sound great.
  • Lines
    Stay productive with 12 programmable line keys supporting up to 34-line key assignments with pagination for autodials and contacts.
  • LCD color display
    A large 4.3" backlight color display shows all your lines and necessary information so you can be more productive.
  • Keys
    4-way navigation cluster with a center select key and a 12-key dial pad with controls for mute, speaker, and headset volume.
  • Add a Poly headset
    Multiple Poly headset options are available to suit your style - in addition to the traditional handset.
  • Ethernet ports
    2 high speed 10/100/1000 Ethernet ports with an integrated switch allow LAN connection for your phone with a passthrough connection to your PC. PoE reduces cable clutter on your desktop, eliminating the need for a separate power adapter.
Poly VVX 450 - VoIP phone - 3-way call capability
VoIP phone
VoIP Services
Zoom, OpenSIP
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SRTP, SDP
Voice Codecs
G.722, iLBC, Opus, G.729A/B, G.711a-law, G.711µ-law
Lines Supported
12 lines
Speakerphone
Call Services
Call Waiting, Call Forwarding, Call Transfer, Call Hold, Call park/pickup
Display
LCD display - colour
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Zoom, OpenSIP, RingCentral
Body Colour
Environmental Standards
ENERGY STAR Qualified
1-year warranty
VoIP phone
Shipping Weight
1.004 kg
Body Colour
Protection
Microban antimicrobial protection
Phone Features
VoIP Services
Zoom, OpenSIP
Call Services
Dialer Location
Base
Conference Call Capability
3-way
Speakerphone
Volume Control
Indicators
Busy lamp field (BLF)
Additional Functions
Call timer, Do Not Disturb (DND), Calling party ID, Connected party ID, Shared Call Appearance (SCA), Bridged Line Appearance (BLA), one-touch speed dial / redial
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SRTP, SDP
Voice Codecs
Lines Supported
12 lines
IP Address Assignment
DHCP, static
Security
256 bit AES, IEEE 802.1X, TLS, EAPoL, SRTP
Power Over Ethernet (PoE) Support
Network Protocols
HTTPS, SRTP
Network Ports Qty
Compatible Software
Voice Features
Comfort noise generation (CNG), voice activity detection (VAD), acoustic echo cancellation (AEC), adaptive jitter buffer (AJB), Poly Acoustic Clarity technology, Poly HD Voice technology, background noise suppression, low-delay audio packet transmission, Poly Acoustic Fence technology, dual tone multi-frequency (DTMF)
Network Features
Lightweight Directory Access Protocol (LDAP), Class 0 PoE, Polycom Device Management Service for Service Providers (PDMS-SP), Poly Zero Touch Provisioning, Poly LENS Cloud Management, IEEE 802.3af, up to 34 SIP registrations
Display
Display Location
Base
Diagonal Size
4.3"
Display Resolution
480 x 272 pixels
Headset jack / RJ-9 , 2 x USB / 4 PIN USB Type A , EHS port , 2 x network / RJ-45
Hearing Aid Compatible
Placing / Mounting
Table-top
Network cable
Stand
ENERGY STAR Certified
Power Consumption
13 W (PoE)
Shipping Width
24 cm
Shipping Depth
23 cm
Shipping Height
5.7 cm
Shipping Weight
1.004 kg
Limited warranty - 1 year
Brand: Poly
