Work where you want and sound your best with the over-ear, boomless Bluetooth headset. Immerse yourself in rich audio, stay in complete comfort with soft ear cushions and an adjustable headband, and keep focused with adaptive ANC.
Get in the zone
Stay focused and keep out the distractions of the outside world with adaptive ANC and over-the-ear design. -
Take your call anywhere
Sound your best where you work with 6 built-in microphones for clear transmit audio without the noise - in a boomless design. -
Extended talk time
Works as long as you do with up to 21 hours of talk time or up to 24 hours of listen time. -
Touch controls
Control your calls and play/pause music with easy-to-use touch controls. With just one click, you can mute yourself with a dedicated button. -
Easy management via Poly Len
Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software. -
Communications platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Voyager Surround 80 UC - headset
- Product Type
- Headset - Bluetooth - wireless - USB-C via Bluetooth adapter
- Compatibility
- Mac, Windows
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Audio Specifications
- Sensitivity 132 dB
- Active Noise Canceling
- Microphones Included
- 10
- Controls
- Volume, power on/off, answer/end, play/pause
- Software Certification
- Certified for Microsoft Teams Open Office
- Product Type
- Series
- Voyager Surround 80 series
- Compatibility
- Mac, Windows
- 19.1 cm
- 7.7 cm
- 18.1 cm
- 275 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Max Operating Distance
- 30 m
Audio Output
- Full size
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 5.3
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Audio/Video Distribution Transport Protocol (AVDTP)
- Active Noise Cancelling Technology
- Adjustable noise cancellation
- Sensitivity
- 132 dB
- Diaphragm
- 40 mm
- Simultaneously Connectable Devices Qty
- 2
- SoundGuard DIGITAL Technology, Smart Sensor Technology
Microphone
- Form Factor
- Built-in
- 10
- Sensitivity
- -37 dB
- Frequency Response
- 20 - 16000 Hz
Remote Control
- Controls
- Software Included
- Poly Lens
- Included Accessories
- Carrying case, USB charging cable, USB-C to USB-A adapter, USB-C to audio cable, BT700 Bluetooth USB-C adapter
- Supported Host Device OS
- macOS, Android, iOS, Windows
- Battery
- Headset battery rechargeable - Lithium Ion
- Run Time (Up To)
- 24 hours
- Run Time Details
- Continuous playback: up to 24 hours , Continuous talk: up to 21 hours
- Recharge Time
- 1 hour
Poly Spare BT700 Bluetooth USB Adapter | In Stock | £58.46 |
