Poly Voyager Surround 80 UC USB-C Headset + USB-C/A Adapter
Quicklinx: HK5KWS00 Mfr#: 8G7T9AA
Recommended Use: Portable electronics, Computer
Connectivity: Wireless
Earcover : Monaural
More than 50 In Stock
£212.28 ex VAT
£254.73 inc VAT
Work where you want and sound your best with the over-ear, boomless Bluetooth headset. Immerse yourself in rich audio, stay in complete comfort with soft ear cushions and an adjustable headband, and keep focused with adaptive ANC.
  • Get in the zone
    Stay focused and keep out the distractions of the outside world with adaptive ANC and over-the-ear design.
  • Take your call anywhere
    Sound your best where you work with 6 built-in microphones for clear transmit audio without the noise - in a boomless design.
  • Extended talk time
    Works as long as you do with up to 21 hours of talk time or up to 24 hours of listen time.
  • Touch controls
    Control your calls and play/pause music with easy-to-use touch controls. With just one click, you can mute yourself with a dedicated button.
  • Easy management via Poly Len
    Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software.
  • Communications platforms
    An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
Poly Voyager Surround 80 UC - headset - USB-C via Bluetooth adapter
Headset - Bluetooth - wireless - USB-C via Bluetooth adapter
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Audio Specifications
Sensitivity 132 dB
Active Noise Canceling
Microphones Included
10
Controls
Power on/off, volume, play/pause, answer/end
Software Certification
Certified for Microsoft Teams Open Office
Series
Voyager Surround 80 series
Compatibility
Mac, Windows
19.1 cm
7.7 cm
18.1 cm
275 g
Earpad Material
Artificial leather
Recommended Use
Max Operating Distance
30 m
Audio Output
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP), Audio/Video Distribution Transport Protocol (AVDTP)
Active Noise Cancelling Technology
Adjustable noise cancellation
Sensitivity
132 dB
Diaphragm
40 mm
Simultaneously Connectable Devices Qty
2
SoundGuard DIGITAL Technology, Smart Sensor Technology
Microphone
Built-in
10
Sensitivity
-37 dB
Frequency Response
20 - 16000 Hz
Remote Control
Controls
Software Included
Poly Lens
BT700 Bluetooth USB-C adapter, carrying case, USB charging cable, USB-C to audio cable, USB-C to USB-A adapter
Supported Host Device OS
macOS, Windows, Android, iOS
Headset battery rechargeable - Lithium Ion
Run Time (Up To)
24 hours
Run Time Details
Continuous playback: up to 24 hours , Continuous talk: up to 21 hours
Recharge Time
1 hour
HK5K Poly Spare BT700 Bluetooth USB Adapter In Stock £58.65
Recommended Use: Computer
Earcover : Monaural
Brand: Poly
