Poly Voyager Surround 80 UC MS Teams Certified USB-C + USB-C/A
Quicklinx: HK5LWS00 Mfr#: 8G7U0AA
Recommended Use: Computer, Portable electronics
Connectivity: Wireless
Earcover : Binaural
15 In Stock
£234.68 ex VAT
£281.61 inc VAT
Work where you want and sound your best with the over-ear, boomless Bluetooth headset. Immerse yourself in rich audio, stay in complete comfort with soft ear cushions and an adjustable headband, and keep focused with adaptive ANC.
  • Get in the zone
    Stay focused and keep out the distractions of the outside world with adaptive ANC and over-the-ear design.
  • Take your call anywhere
    Sound your best where you work with 6 built-in microphones for clear transmit audio without the noise - in a boomless design.
  • Extended talk time
    Works as long as you do with up to 21 hours of talk time or up to 24 hours of listen time.
  • Touch controls
    Control your calls and pause/play your music with easy-to-use touch controls. With just one click, you can mute yourself with a dedicated button.
  • Easy management via Poly Len
    Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software.
  • Certified for Microsoft Teams
    Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more. Plus, this headset meets Microsoft Teams Open Office premium microphone specification.
Poly Voyager Surround 80-M UC - headset - USB-C via Bluetooth adapter
Headset - Bluetooth - wireless - USB-C via Bluetooth adapter
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer
Headphones Form Factor
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Audio Specifications
Sensitivity 132 dB
Microphones Included
10
Controls
Power on/off, volume, play/pause, answer/end
Software Certification
Series
Voyager Surround 80 series
Compatibility
Mac, Windows
19.1 cm
7.7 cm
18.1 cm
275 g
Earpad Material
Artificial leather
Recommended Use
Max Operating Distance
30 m
Audio Output
Full size
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.3
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP), Audio/Video Distribution Transport Protocol (AVDTP)
Sensitivity
132 dB
Diaphragm
40 mm
Simultaneously Connectable Devices Qty
2
SoundGuard DIGITAL Technology
Microphone
Built-in
10
Sensitivity
-37 dB
Frequency Response
20 - 16000 Hz
Remote Control
Controls
BT700 Bluetooth USB-C adapter, carrying case, USB charging cable, USB-C to audio cable, USB-C to USB-A adapter
Supported Host Device OS
macOS, Windows, Android, iOS
Headset battery rechargeable - Lithium Ion
Run Time (Up To)
24 hours
Run Time Details
Continuous playback: up to 24 hours , Continuous talk: up to 21 hours
Recharge Time
1 hour
Recommended Use: Portable electronics
Earcover : Binaural
Brand: Poly
