Smart sensor technology reacts when you put the headset on. Interact with Siri, Google Now, or Cortana by pressing the call button. With technology this nimble, Voyager Legend is the first truly intelligent Bluetooth headset.
Sensors react when you put on or take off your headset. Putting on your headset will: automatically answer an incoming call, transfer an active call from your phone, and resume streaming audio. Taking off your headset will: transfer an active call to your phone, pause streaming audio, and lock the Call button to avoid accidental calls. -
Best noise & wind canceling
Experience the best noise and wind canceling formula: 3 mics + 3 layers of wind protection. Sound your best in the worst traffic, street noise, or crowded areas. -
Call announce & voice-answer
Voyager Legend accesses your contact details in your phone to announce who's calling and then waits for you to say "Answer" or "Ignore." -
Voice commands
Tap the Voice button on the mic boom and use your voice to check battery level, connection status, and more. You can also ask "What can I say?" to hear a list of voice command options. -
Streaming audio
Stream music, podcasts, movies, and more from smartphones and tablets. Sensors will pause audio for incoming calls and when you slip off the headset. -
Comfortable & durable
Comfort-tested for extended wearing, the flexible materials and balanced lightweight design is also durable enough to withstand daily wear and tear. Silicone gel eartips come in three sizes so you can find the best fit. -
Convenient controls
Separate mute, call, volume, and power buttons provide easy access and control. Toggle, slide, or tap the button you need without having to look at the headset. It's even easier now to switch off the power to extend battery readiness. -
Snap-fit magnetic connection
The magnetic connection makes charging quick and easy. -
Find Myheadset Android app
There are two ways to find your misplaced Plantronics headset. Send a tone: if you think your headset is powered on and within 33ft/10m of your phone, play a sound file through your headset and hear it signal where it is. Track it: if you think your headset is powered off or too far away, review its recent activity on a time-stamped map to discover where your headset was last used.
- Poly Voyager Legend - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Additional Functions
- DSP
- Headphones Form Factor
- In-ear - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0 EDR
- Controls
- Answer/end
- 2-year warranty
- Product Type
- DSP
- 18 g
- Recommended Use
Audio Output
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 3.0 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP)
- Equaliser
- 20 bands
- Voice control, MultiPoint Technology
Remote Control
- Controls
- Answer/end
- Connector Type
- (magnetic)
- Cable Details
- USB charge cable
- P2i
- Battery
- 1 x headset battery Lithium Ion
- Included Qty
- 1
- Run Time (Up To)
- 7 hours
- Standby Time
- 264 hours
- Recharge Time
- 90 min
- Limited warranty - 2 years
