Poly Voyager Legend Bluetooth Headset
Quicklinx: HM4KWS00 Mfr#: 7W6B8AA#ABB
Recommended Use: Portable electronics
Connectivity: Wireless
Earcover : Monaural
11 In Stock
£55.92 ex VAT
£67.10 inc VAT
Unsurpassed audio and comfort, smart technology to make calling a breeze.
  • Mic check, 1-2-3
    Sound your best in the worst traffic, street noise, or crowded areas. With precision audio, multi-microphones optimize your voice and minimize noise caused by wind, movement, and background sounds.
  • Never miss a beat
    The rechargeable pocket-sized charge case protects the headset and holds up to two full charges, so Voyager Legend will always be good to go.
  • Protection from the elements
    This headset works as hard as you do, through rain, sweat and the inevitable coffee spill. Protected against sweat and moisture damage with P2i technology.
  • You're in command
    Separate mute, call, volume, and power buttons provide easy access and control. Toggle, slide, or tap the button you need without having to look at the headset.
  • Comfortable and durable
    Comfort-tested for extended wearing, the flexible materials and balanced lightweight design is durable enough to withstand daily wear and tear. Silicon gel eartips come in three sizes so you can find the best fit.
Poly Voyager Legend - headset
Headset - Bluetooth - wireless
Recommended Use
Additional Functions
DSP
English / Europe
Headphones Form Factor
In-ear - over-the-ear mount
Wireless
Wireless Technology
Bluetooth
Microphone
Boom
Microphone Noise Cancelling
Controls
Answer/end, mute, volume control, play/pause, voice assistant
Intelligent Assistant
Siri, Google Assistant
1-year warranty
DSP
18 g
Recommended Use
Voice alerts, echo cancellation
Protection
Sweat-resistant, moisture-resistant
Max Operating Distance
10 m
English / Europe
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP)
Equaliser
20 bands
Simultaneously Connectable Devices Qty
8
Smart Sensor Technology, sidetone detection, voice control, MultiPoint Technology, SoundGuard Technology
Microphone
Boom
Frequency Response
100 - 6800 Hz
Noise Cancelling
3-microphone noise cancellation
Remote Control
Controls
Internet of Things (IoT)
Magnetic USB charging cable, pin adapter
Headset battery rechargeable - lithium polymer
Run Time (Up To)
7 hours
Run Time Details
Continuous talk: up to 7 hours , Continuous talk (with included charging case): up to 21 hours
Standby Time
11 days
Recharge Time
1.6 hours
Limited warranty - 1 year
HM4K Poly - USB adapter - USB to 24 pin USB-C In Stock £12.86
HM4K Poly - USB adapter - 24 pin USB-C to USB In Stock £12.82
Earcover : Monaural
Brand: Poly
