Mic check, 1-2-3
Sound your best in the worst traffic, street noise, or crowded areas. With precision audio, multi-microphones optimize your voice and minimize noise caused by wind, movement, and background sounds. -
Never miss a beat
The rechargeable pocket-sized charge case protects the headset and holds up to two full charges, so Voyager Legend will always be good to go. -
Protection from the elements
This headset works as hard as you do, through rain, sweat and the inevitable coffee spill. Protected against sweat and moisture damage with P2i technology. -
You're in command
Separate mute, call, volume, and power buttons provide easy access and control. Toggle, slide, or tap the button you need without having to look at the headset. -
Comfortable and durable
Comfort-tested for extended wearing, the flexible materials and balanced lightweight design is durable enough to withstand daily wear and tear. Silicon gel eartips come in three sizes so you can find the best fit.
- Poly Voyager Legend - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Additional Functions
- DSP
- Localisation
- English / Europe
- Black
- Headphones Form Factor
- In-ear - over-the-ear mount
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Microphone
- Boom
- Microphone Noise Cancelling
- Controls
- Answer/end, mute, volume control, play/pause, voice assistant
- Intelligent Assistant
- Siri, Google Assistant
- 1-year warranty
- Product Type
- DSP
- 18 g
- Black
- Recommended Use
- Voice alerts, echo cancellation
- Protection
- Sweat-resistant, moisture-resistant
- Max Operating Distance
- 10 m
- Localisation
- English / Europe
Audio Output
- Wireless
- Bluetooth
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Hands-Free Profile (HFP), Headset Profile (HSP)
- Equaliser
- 20 bands
- Simultaneously Connectable Devices Qty
- 8
- Smart Sensor Technology, sidetone detection, voice control, MultiPoint Technology, SoundGuard Technology
Microphone
- Boom
- Frequency Response
- 100 - 6800 Hz
- Noise Cancelling
- 3-microphone noise cancellation
Remote Control
- Controls
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Included Accessories
- Magnetic USB charging cable, pin adapter
- Battery
- Headset battery rechargeable - lithium polymer
- Run Time (Up To)
- 7 hours
- Run Time Details
- Continuous talk: up to 7 hours , Continuous talk (with included charging case): up to 21 hours
- Standby Time
- 11 days
- Recharge Time
- 1.6 hours
- Limited warranty - 1 year
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £12.86 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
