Poly Voyager Free 60/60+ Earbuds White
Quicklinx: HK6QWS00 Mfr#: 8L5B1AA
£145.31 ex VAT
£174.37 inc VAT
Whether you're on a video call or into your playlists, these wireless earbuds are designed to keep you productive, connected and entertained.
Advanced noise reduction
Keep out distractions with adaptive Active Noise Canceling (ANC).
Clear, distraction-free calling
Three microphones per earbud and WindSmart technology for clearer outdoor calls.
Easy connection to Bluetooth® devices
Connect up to two Bluetooth® devices at any time with multipoint technology.
Comfortable design
Discreet wireless earbud design.
  • Clear, distraction-free calling
    Stay focused and keep out the distractions of the outside world with adjustable hybrid adaptive active noise cancelling (ANC).
  • Advanced noise reduction
    With three microphones per earbud and WindSmart technology for clearer outdoor calls, you'll always be heard above the background noise.
  • Discrete, comfortable design
    Designed for hours of comfortable use in even the most demanding enterprise environments, you'll look and sound your best on calls with these discreet wireless earbuds.
  • Easy connection to Bluetooth devices
    Connect up to two Bluetooth devices at any time with multipoint technology (remembers up to 8 Bluetooth devices).
  • Easy management via Poly Lens
    Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software.
  • Optimized for use with leading communications platforms
    An IT manager's dream, these earbuds were created for communication and are optimized and certified to work with top virtual meeting providers.
Poly - eartip for true wireless earphones
Eartip
Packaged Quantity
2 (specifications are for single item)
Intended For
True wireless earphones
White
Packaged Quantity
Eartip
Intended For
White
Brand: Poly
