We couldn't build a wall around you to block out background noise, so we did the next best thing: created a "focus zone" with the new Voyager Focus 2 headset. All you hear is your call with three levels of hybrid active noise canceling (ANC). All they hear is you with our pro-grade microphones using Poly Acoustic Fence technology. It's all the Poly next-level engineering you expect with the wear-it-all-day comfort you need. Connect to a computer with the included BT700 USB-A adapter and to a mobile via Bluetooth v5.1. Keep your headset fully charged at all times using a desktop charging stand. Microsoft Teams version supports easy collaboration with a dedicated Teams button for instant access to the Teams App.
Smartly engineered for audio perfection
Create a focus zone all around you with the Voyager Focus 2. All you hear is your call with three levels of hybrid active noise canceling (ANC). All they hear is you with the pro-grade microphones using Poly Acoustic Fence technology. It's all the Poly next-level engineering you expect with the wear-it-all-day comfort you need. -
3 levels of hybrid active noise cancellation
Experience acoustic excellence others can't touch. Loud and distracting background is just gone with 3-levels of advanced digital hybrid ANC. With this headset, you're ready to have the most critical conversations with confidence. -
They'll hear what they're meant to hear
It's you - loud and clear. That's all callers hear. The discreet microphone boom on the Voyager Focus 2 is not only ultra-noise canceling but, with its multiple microphone Acoustic Fence technology, literally creates a virtual noise-free bubble in front of your mouth. It's so good it even meets the Microsoft Teams Open Office premium microphone requirements. The focus stays on you, right where it belongs. -
Comfort that's easy on the ears and easy on your head
Stay engaged during a full day of calls wearing an ultra-comfortable headband with super cushioned sling and plush ear cushions. The Voyager Focus 2 is designed with you in mind - stay focused and productive all day. -
Stay connected and powered up all day
With up to 19 hours of talk time it lasts all day. If you need more just plug it in and use as a corded headset. Voyager Focus 2 UC: connect to a computer with the included BT700 USB adapter for improved wireless range. Or connect to your mobile via Bluetooth v5.1.
- Poly Voyager Focus 2 UC - headset - with charging stand
- Product Type
- Headset - Bluetooth - wireless, wired - USB-A
- Recommended Use
- Phone, computer
- Additional Functions
- SoundGuard DIGITAL
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute, volume, power on/off, answer/end, ANC mode
- Software Certification
- Certified for Microsoft Teams
- Compatible Software
- Cisco WebEx, MiCollab Client, Microsoft Teams, Zoom, Skype for Business
- 2-year warranty
- Bundled with
- Charging stand
- Product Type
- 5.4 cm
- 18.6 cm
- 21 cm
- 175 g
- Recommended Use
- Phone, computer
- Max Operating Distance
- 50 m
- Bundled with
- Charging stand
Audio Output
- On-ear
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Advanced Hybrid Active Noise Cancellation
- Acoustic Fence technology
Microphone
- Boom
Remote Control
- Controls
- Included Accessories
- Carrying case, charging cable, Bluetooth USB-A adapter
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 560 mAh
- Run Time (Up To)
- 40 hour(s)
- Run Time Details
- Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 19 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
- Standby Time
- 30 days
- Recharge Time
- 2 hour(s)
- Limited warranty - 2 years
