Create a focus zone around you with the Voyager Focus 2, stereo Bluetooth headset. Smartly engineered for audio perfection – all you will hear is your call. And the focus stays on you, right where it belongs.
Immersive experience
Stay focused while on calls or listening to music/media with stereo sound. -
Easy to use
An easy-to-use headset with smart sensors for answering/muting calls and playing/pausing music. The intelligent microphone boom automatically maintains left and right audio no matter which side the headset is worn on. -
No need for battery anxiety
Keep your headset fully charged using the included desktop charging stand. You can also extend the battery life by using it corded, with audio over USB mode. -
Choose your device
Works with your choice of device: PC via included BT700 USB-A or USB Type-C ? Bluetooth adapter and mobile phones via Bluetooth v5.1. -
Smart Sensors
Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free. -
Optimized for top platforms
Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
- Poly Voyager Focus 2 - headset - USB-A via Bluetooth adapter
- Product Type
- Headset - Bluetooth - wireless, wired - USB-A via Bluetooth adapter
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- MEMS-directional
- Microphones Included
- 4
- Controls
- Mute, volume, power on/off, answer/end, ANC mode
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Certified for Microsoft Teams
- Product Type
- 15.5 cm
- 6.7 cm
- 18.2 cm
- 176 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Max Operating Distance
- 50 m
Audio Output
- On-ear
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 32 mm
- Adjustable Headband
- Simultaneously Connectable Devices Qty
- 2
- Dynamic EQ optimised
Microphone
- Boom
- MEMS-directional
- 4
- 100 - 6800 Hz
Remote Control
- Controls
- Connector Type
- USB (USB Type-A)
- Included Accessories
- Charging stand, charging cable, travel pouch, BT700 Bluetooth USB adapter
- Cable Details
- Micro-USB charging cable
- Supported Host Device OS
- Windows 10, macOS, Windows 11
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 560 mAh
- Run Time (Up To)
- 40 hours
- Run Time Details
- Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 18 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
- Standby Time
- 30 days
- Recharge Time
- 2 hours
- Shipping Width
- 21 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 11.5 cm
- Shipping Weight
- 712 g
Poly Voyager USB-A Charging Stand | In Stock | £21.69 |
Poly Wireless Headset System Base for Bluetooth headset - for Poly Voyager | In Stock | £91.05 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.11 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
