Create a focus zone around you with the Voyager Focus 2, stereo Bluetooth headset. Smartly engineered for audio perfection – all you will hear is your call. And the focus stays on you, right where it belongs.
Immersive experience
Stay focused while on calls or listening to music/media with stereo sound. -
Easy to use
An easy-to-use headset with smart sensors for answering/muting calls and playing/pausing music. The intelligent microphone boom automatically maintains left and right audio no matter which side the headset is worn on. -
It's your call
Stay productive with up to 19 hours of wireless talk time (ANC on) and extend the battery life by using it corded, with audio over USB mode. -
Choose your device
Works with your choice of device: PC via included BT700 USB-A or USB Type-C ? Bluetooth adapter and mobile phones via Bluetooth v5.1. -
Smart sensors
Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free. -
Optimized for top platforms
An IT manager's dream, this headset was created for communication and is optimized and certified to work with top virtual meeting providers.
- Poly Voyager Focus 2 - headset - USB-A via Bluetooth adapter
- Product Type
- Headset - Bluetooth - wireless, wired - USB-A via Bluetooth adapter
- Recommended Use
- Portable electronics, computer
- Black
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- MEMS-directional
- Microphones Included
- 4
- Controls
- Mute, volume, power on/off, answer/end, ANC mode
- Environmental Standards
- TCO Certified Headsets 9
- Software Certification
- Certified for Microsoft Teams
- Product Type
- 15.5 cm
- 6.7 cm
- 18.2 cm
- 176 g
- Black
- Earpad Material
- Artificial leather
- Recommended Use
- Max Operating Distance
- 50 m
Audio Output
- On-ear
- Wireless, wired
- Bluetooth
- Bluetooth Version
- Bluetooth 5.1
- Sound Output Mode
- Stereo
- 20 - 20000 Hz
- Diaphragm
- 32 mm
- Adjustable Headband
- Simultaneously Connectable Devices Qty
- 2
- Dynamic EQ optimised
Microphone
- Boom
- MEMS-directional
- 4
- 100 - 6800 Hz
Remote Control
- Controls
- Connector Type
- USB (USB Type-A)
- Included Accessories
- Charging cable, travel pouch, BT700 Bluetooth USB adapter
- Cable Details
- Micro-USB charging cable
- Supported Host Device OS
- Windows 10, macOS, Windows 11
Sustainability Information
- TCO Certified
- Battery
- Headset battery rechargeable - Lithium Ion
- Capacity
- 560 mAh
- Run Time (Up To)
- 40 hours
- Run Time Details
- Continuous talk (noise cancelling ON): up to 16 hours , Continuous talk (noise cancelling OFF): up to 18 hours , Continuous hearing (noise cancelling ON): up to 24 hours , Continuous hearing (noise cancelling OFF): up to 40 hours
- Standby Time
- 30 days
- Recharge Time
- 2 hours
- Shipping Width
- 21 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 11.5 cm
- Shipping Weight
- 712 g
Poly Voyager USB-A Charging Stand | In Stock | £21.79 |
Poly - USB adapter - USB to 24 pin USB-C | In Stock | £13.01 |
Poly - USB adapter - 24 pin USB-C to USB | In Stock | £12.95 |
